backlash
10-20-2004, 12:35 AM
Hey guys, this is one awesome website 8)
I am the proud owner of a 05 scion in the black cherry pearl color [and man does it turn heads!] I purchased it with the automatic transmission and am starting to think that there is a problem with the front differential / trans. In stop and go traffic, or when ever accelerating from a rolling stop the car seems to take a while to hook up and move. Its as if the differential or some component in the trans has alot of backlash or wasnt dialed in right when setup. I can even hear a minor clunk (in the are of the cv shaft where they go into the trans) when this happens. You can test for this by driving slowly and tapping the gas for a second and letting go......hopefully u wont feel what i feel: trans disenguaging from the motor and then hooking up too late. It also does it from deceleration or when applying brakes after decel, then adding gas...less than a second later it hooks up and then moves, by this point youve added more gas and it lunges. Sounds odd right....is it normal to hear some clunking and a feeling of disconnection between the trans / engine? Also when coasting @ highway speeds and suddenly accelrating, it seems that there is also some lag [and sometimes a jerk in movement]...is this normal? Any idea what part might be out of spec here ?
Other than that the rubber seal on the drivers side window doesnt seem to be "squeeging" the glass well on a rainy day but thats the least of my troubles now!
