View Full Version : KSport Kontrol Coilovers for 2nd gen xB
NurSpec
10-03-2007, 01:43 AM
Hey Guys,
I spoke with my contact over at Ksport and they have completed testing for the 2nd gen xb coilovers. Retail comes in at 1400. Let me know what you guys think:)
Ksport Kontrol Pro
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
http://www.g35parts.com/9083/osc/images/ksport350z.jpg
They are retailing for 1400.
Bigfieroman
10-03-2007, 02:18 AM
Is that front only, or front and rear?
NurSpec
10-03-2007, 02:45 AM
The kit contains a coilover for each corner of your car. The picture here is not the exact kit for the xB, but it gives you a great idea of what to expect.
NoLimitzBuilt
10-03-2007, 03:23 PM
I posted this yesterday asking some questions of what people thought on the kit. There was some height questions they where asking about.
NoLimitzBuilt
10-03-2007, 08:12 PM
I just went and test drove the xB with the K Sport Coilovers on it. It is a huge difference. That thing handled good, and it is not even adjusted correctly. I didnt have time to sit and play with it alot, but wow what a difference. This will be a great kit for sure.
NurSpec
10-04-2007, 04:13 AM
Ksport is local to me in AZ. They really work hard when it comes to testing on the street and track.
NoLimitzBuilt
10-04-2007, 03:42 PM
Where is your shop at?
