supercharger question . . . . .2007
Old Oct 3, 2007 | 08:13 AM
Ex_sPEC's Avatar
Default supercharger question . . . . .2007
will my current mod are mmw header and cc magna flow exhaust and injen intake . . . .getting my s/c install monday. . . .jus wanted to know that if i still need my stock intake system, for the sc install ? ? ?2007 btw thanks
Old Oct 3, 2007 | 08:29 AM
sEcTs's Avatar
well just let u know it's better to be at the dealer after swapping to stock mod so they can't be _____ing about it
Old Oct 3, 2007 | 05:25 PM
Gerard_gmaiz's Avatar
You can customise the injen intake for better looks and it always help some colder air
that way the s/c intake box get eliminated
I have it that way in my tC
Old Oct 3, 2007 | 05:35 PM
CDogbert's Avatar
I believe you need a part of your airbox for the s/c install, if you're having the factory put it on. I don't think they'll put the supercharger in with an aftermarket intake, and they probably won't be too happy when they see the header.
EDIT: No, they won't put it on with an aftermarket intake. A CAI will make the TRD-reflashed ECU run too lean. That's why you can't have the TRD CAI if you want the factory s/c.
I hope you're running some kind of ECU management system. Your engine is probably going to blow up soon.
Old Oct 3, 2007 | 05:45 PM
torqueTc's Avatar
^^^ you need the bottom of your stock airbox. They may not install your s/c with the header pipe - but your exhaust isnt an issue.
You will loose your CAI, but you do know what a s/c does, and why the stock TRD reflash leans out right? It cannot adjust properly to the airflow so the ECU doesnt know what to do. It cannot read from 2 different points at once, and there is too much flux in the air mix.
Old Oct 3, 2007 | 05:48 PM
Sleep3r's Avatar
no no no
unless you have some sort of EMS
Old Oct 3, 2007 | 06:17 PM
yes
I have an apexi neo and a good set up
I ran 217whp at 7psi
the s/c runs better with the custumise CAI
Old Oct 3, 2007 | 06:59 PM
Ex_sPEC's Avatar
umm i jus want a answer do i need the stock intake on. . . .or will they replace it ? ? ?
Old Oct 3, 2007 | 07:40 PM
megrog2's Avatar
Originally Posted by torqueTc
you need the bottom of your stock airbox....You will loose your CAI
Old Oct 3, 2007 | 07:49 PM
CDogbert's Avatar
Umm we gave you one, and we're letting you know about other things that you need to know if you don't want your engine to blow up. I'm going to break this down for you as hard as I possibly can, since you're getting an attitude with people who are otherwise trying to be helpful to you.
Do you need the stock airbox?
Will they install it with your Injen CAI already installed?
Do you want to just put the CAI back on after the supercharger install?
Originally Posted by Sleep3r
no no no unless you have some sort of EMS
Old Oct 3, 2007 | 10:12 PM
beedee's Avatar
cDog laying the smackdown! hopefully his question has been answered lol!
Old Oct 4, 2007 | 08:35 AM
Ex_sPEC's Avatar
thanks jus put back my stock
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
