Anyone try these spacers off Ebay?
Old Oct 3, 2007 | 12:39 PM
bbszero's Avatar
Default Anyone try these spacers off Ebay?
Any experience with this one? thanks.
http://cgi.ebay.com/ebaymotors/4x100...QQcmdZViewItem
Old Oct 3, 2007 | 01:13 PM
swartzautoman's Avatar
sportline is a good compainy.
are you wanting to do just the back or all the way around.
the bad part about using a wheel spacer it it puts more stress on the bearing and studs. this type you are looking salves the stud broblem. most wheel spacers require that you knock the old studs out and install longer ones. "very bad idea" iv worked in a few auto shops and it was always our policy to get a car with wheel spacers out of our shop.
we would refuse to to and tire or wheel work on them.
its just dangerous.
if you are interested in doing just the rear you sould go with a OTG style hub spacer. the spacer goes behind the entire hub essembely and is much saver, is comes with much stronger bolts.
you can get them in any size you want. and its about the same price for a set.
you can get them from keoki. ( scion life member )
i have 15 x 7 38mm off set rims with stock tires and 20mm hub spacers from keoki. its perfet
Old Oct 3, 2007 | 09:33 PM
andrewdustin's Avatar
spacers = : (
OTG Shims = : )
Old Oct 5, 2007 | 05:50 AM
Just1n's Avatar
Wagonistas
F%#@ yea...BUMP FOR KEOKI
Buy them here>>>>> http://www.scionapocalypse.com/forum...opic.php?t=146
reniculous1
Aug 14, 2015 03:16 PM
Subaru86
Jul 31, 2015 04:00 AM
Krysune
Scion xB 2nd-Gen Wheel & Tire
Jul 11, 2015 09:30 PM
