BByutiful
10-20-2004, 04:44 PM
i was wondering if anyone knew how to point the angle of the headlight down a little bit. i have had my HIDS in just a couple weeks ago, and i know im blinding people. lol... but yea, any suggestions or what not will be appreciated. thanks.
Look on the back of the headlight housings. You will see an 8mm silverish grey "bolt". Use these to adjust the level up or down. :)
BrockAbabba
10-20-2004, 05:04 PM
I've heard this a lot as I researched whether to put mine in or not. The best solution I've found so far was to purchase the 'eyelids' for your box. The beam will always be mishapen, but that should keep you alive while oncoming vehicles struggle to see the road.
hahajoey
10-20-2004, 05:11 PM
the bolt is like a bolt that has a big flat washer like wheel with lil teeth on it...
one direction will lower the beam and the other way is to raise the beam..
park on a flat surface with a nice flat perpendicular wall.
aim it down and even with both, keep messing with it so that
when u drive, and you can see your beam doesn't pass the truck on cars.
BByutiful
10-21-2004, 05:58 AM
thanks for all your help. :D
