Winter is coming again, tire storage reminder
Winter might already be knocking on a few of your doors or at least the colder temperatures it brings. This is an FYI for you. I know this won't apply to everyone but its good info none the less. If any of you are running Track Tires or Drag radials such as the Nitto 555R, the 555RII, Nitto NT01's of similar ultra performance track or RT tires (Falken 615, BFG drags etc.). Nitto Suggest you take them off for the winter if you live in a climate where temperatures drop below 32 degrees. They recommend storing them indoors at a temperature above 32 degrees and at 1/2 the normal running pressure. Drag radials and RT Tires are prone to cracking at freezing temperatures if this occurs have the tire inspected immediately. Attached is a picture of a tire that has cracked due to improper storage at cold temperatures. Oh and BTW our winter/snow tire stock is in. www.discounttiredirect.com
They shouldn't, Nitto put out the notice for the 555R the 555RII and the NT01's the others should be fine. The RT and Drag radials are made with a special rubber compound that performs best at high temperatures (that’s why heating them up makes them stickier). You NeoGens are still performance tires but they use a most versatile compound.
my06tc
Jun 25, 2015 12:18 AM
eddienj
Scion tC 1G ICE & Interior
Jan 27, 2015 03:53 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
