$200 to move TPMS?
Old Oct 5, 2007 | 12:58 AM
houstonhelix's Avatar
Default $200 to move TPMS?
I got a $200 quote from my local dealership to move the TPMS from my old set of wheels to my current already installed aftermarket rims. Is that a realistic price?
RON
Old Oct 5, 2007 | 02:20 AM
Bigfieroman's Avatar
NO. The tpms sensors are basically just valve stems. Even if they broke down all 8 wheels, swapped the valve stems, and re-mounted/balanced all 8, $200 is STILL really steep.
Old Oct 5, 2007 | 10:38 AM
KY_Chuck's Avatar
Sounds high, but basically you're paying to mount and balance 8 wheels. Typical price for mount/balance is $18-25/wheel. The dealer's at the high end. You may find someone to do it a little cheaper.
I'm assuming you want rubber stems in the stock wheels and that you plan to use them at some point. If not, they should only charge you for 4 wheels.
Old Oct 5, 2007 | 12:57 PM
BloodHoundFan's Avatar
The estimate I got from my dealer to swap TPMS sensors into a new set of wheels was $90.
Old Oct 5, 2007 | 11:16 PM
xseveredveganx's Avatar
Utah Scions
I'm just curious how much the TPMS sensors are outright...
Seems like it would be nice to have a set of nice wheels for the summer and use the stocks for winter. I know here in Utah they use salt on the roads. Up in Wyoming it's dirt.
I'd see it being easier just slapping on steelies with customs a lot easier than having to break everything down.
And you don't neccessarily have to get them rebalanced. If the tire shop is good enough and your wheels are already balanced well, they'll mark where the valve stem and the wheel weights are and go from there. I've done tires for too long! Lol!
Old Oct 6, 2007 | 01:01 AM
to buy new TPMS sensors they are very pricey...somewhere between 3 and 5 hundred.
Old Oct 6, 2007 | 01:46 AM
Utah Scions
EEEEP!!! Never mind...
I'd be better off putting the TPMS in the 20's and leaving the stocks with nothing.
Old Oct 6, 2007 | 04:44 AM
roXor_boXor's Avatar
Yup.
Tire Rack says
TPMS VALVE SENSOR
$344.00 for a quantity of 4 for new install on new wheels.
Probably the main reason most people just skip it.
Old Oct 30, 2007 | 02:42 PM
danoiboi's Avatar
I am also looking at places to swap my 07 sensors out and put them into my aftermarket wheels.
Does anyone know where I could do this for cheap (where did you go and how much you paid).
I think i would only pay maybe 120 bucks....
did any of you do this yourself? how hard was it and did you need any special tools.
thanks.
Old Oct 31, 2007 | 02:33 AM
theGREEK's Avatar
got my rims at discount tire and made sure the tpm system fit before i bought the rims. They fit and they charged me a few bucks to reinstall them on the new rims
Old Oct 31, 2007 | 06:01 PM
808-213-503's Avatar
I bought my tires online through Discount Tire, and they didn't charge me extra for reinstalling the TPMS, except for the "wheel installation kit" which basically includes all the keyed lugs. The 'out the door' price is exactly what I paid when I went into the store to have them installed.
Old Nov 1, 2007 | 05:09 AM
danoiboi's Avatar
so...houstonhelix....i just did exactly what you are looking to do. $200 is definitely pricey.
Call around local shops, they all quote a little differently, i found the lowest quote @ $110. but i ended up going to discount tire and they charged me $124 to install he new sensors. This includes all the mounting/dismounting fees and balancing of the new wheels.
Just a quik comparison, firestone wanted $250.=\
Old Nov 2, 2007 | 01:03 PM
JRT's Avatar
JRT
so the tpms sensor in the valve stem. I was hopeing it was just, un-screwed the tpms off the valve stim.
Old Nov 2, 2007 | 01:39 PM
shorberg's Avatar
the charge is for the labor to reprogram the TPMS to your car. you can't just pull them and put them back on, they have to be recalibrated and reprogrammed. that's 50$ less than i pay my service department to swap wheels around on a car and i am the DEALER . . .
pay 'em to do it right, or you might regret it.
Old Nov 2, 2007 | 03:56 PM
danoiboi's Avatar
I did not have to reprogram my tpms (this was an extra 40 dollar charge which i opted not to do)
the reason i didn't have to was b/c i think both my tires had the same rated max psi. so there wasn't anything to change.
This is what i was charged for:
1)mounting/dismounting of tires to get to the tpms sensors (this will be more if you already have tires mounted on your aftermarket set since you will have to do an extra dismount)
2)very SMALL charge to physically move the tpms valve stems and pop them into your aftermarket rims. (this will be more if your aftermarket rims are not compatible and you have to buy a kit, most of the time this is not the case)
3)balancing the tires.
Go to shops that have done it before, otherwise they will not give you accurate quotes...discount tire is pretty good about it
Old Nov 2, 2007 | 03:59 PM
danoiboi's Avatar
oh yea, and i've had mind for a few days now and no problems whatsoever, no tpms light....
Old Nov 2, 2007 | 04:05 PM
shorberg's Avatar
meh
Old Nov 2, 2007 | 09:13 PM
Same here. I had the sensors swapped over a month ago and have had no problems/lights/etc since. I don't see why need reprogrammed, there is a reset button to acclimate them to tire pressure, and they were still programmed to the car despite being off the car for ~4 weeks.
Old Nov 2, 2007 | 09:19 PM
tC9o9's Avatar
i didnt have my sensors swapped in when i switched wheels, the light came on about two weeks later, stayed on for about two days.. and now its gone again( been about two more weeks)
so i have no clue whats going on. but i dont really care for it either.
Old Nov 2, 2007 | 09:26 PM
shorberg's Avatar
there is a transponder id # on the valve stem, when you swap it to the other wheels, you have to re-register it to the system.
