Headlight Aim Question
Old Oct 9, 2007 | 04:14 AM
7thgear's Avatar
Default Headlight Aim Question
I'm trying to reaim my headlights so that more light output is shown on the ground. So my question is: if I keep turning the screw behind the headlight that adjusts the beam vertically, counter-clockwise, which lowers the beam, will that actually give me more light output on the ground? And will that screw keep turning forever or does it actually have a stopping point? Better yet, is there a limit on how low the beam can go down?
Thanks.
Old Oct 9, 2007 | 04:22 AM
captainlaziness's Avatar
I dunno. But I'd think that the more you adjust towards the ground, the less distance in front of the car you will have.
Old Oct 9, 2007 | 04:29 AM
RodC's Avatar
I found that there is practically no limit to how high you can aim the beams. I have been driving around with my beams pointing skywards for the last few days because I never got around to fixing the aim after taking them apart. It's fun to drive on the freeway and light up the overhead signs and the headliners of the cars in front. Bet people hate me for it though.
Old Oct 9, 2007 | 04:32 AM
Yanki01's Avatar
the is a limit. put the lights up against a wall and lower it maybe 2-3 turns. that should be more than enough.
Old Oct 9, 2007 | 05:12 AM
7thgear's Avatar
so once i reach the limit, will the screw just lock or will the beam just not go down any further?
so you say 2-3 turns, meaning 2-3 full 360 degree turns?
Old Oct 9, 2007 | 05:27 AM
Noodle's Avatar
actually, counter clockwise will raise the beam. Clockwise will lower the beam. The right way to aim LB is to aim them parallel to the ground. Face a wall 15-20 ft away, adjust the beam to align them with the height of your headlights.
Old Oct 9, 2007 | 05:53 AM
7thgear's Avatar
no it's counterclockwise. i checked the manual.
Old Oct 9, 2007 | 06:30 AM
RodC's Avatar
Lolz, it depends what way you are facing, people. If you stand behind the headlight and face in the direction of the beam, then a counterclockwise turn will lower the beam. If, for some reason, you are standing in front of the headlights and letting them shine on your legs, then a clockwise turn will lower the beam.
Old Feb 9, 2008 | 02:13 AM
no-tec's Avatar
What about making the headlights turn left or right? I just installed some HIDs and they are angled cockeyed. How do I get them to point straight again?
Old Feb 9, 2008 | 02:18 AM
cavalierkid888's Avatar
Actually clockwise is clockwise and counterclockwise is counterclockwise no matter where you're standing....unless your standing underneath the piece you are turning, if that makes sense.
Old Feb 9, 2008 | 02:20 AM
CSUnited14's Avatar
Smack them because you just bought a dee dee deee set
Old Feb 9, 2008 | 02:29 AM
no-tec's Avatar
Well I baked them as well and manually put all the screws back in so I'm assuming it happened somewhere in that process, that some screws were tighter than others. and I bought the 3bSpecialists set so I don't think it's its the bulbs
Old Feb 9, 2008 | 02:31 AM
no-tec's Avatar
No it's not silly. CCW facing the car is one way and CCW inside the car facing forward is another way.
Old Feb 9, 2008 | 02:50 AM
RodC's Avatar
Dur.
Old Feb 9, 2008 | 03:00 AM
My brain hurts. lol Well maybe cuz i'm thinking the adjustment piece is horizontal...but it's not it must be vertical then. If that makes sense....hmmm i'm gonna go sit in the corner now lol
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
2006whitexb
Mar 11, 2015 12:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
