Your AFR Readings.....
Old Oct 14, 2007 | 10:26 PM
FireStorm's Avatar
Default Your AFR Readings.....
Well i Put the AEM UEGO Wideband in today and tell me if this is normal....
1st-4th gear WOT is Constant 11.9-12.1 Full Boost 6.5psi Never Higher Never Lower
5th Gear WOT is 11.2-11.4 @ WOT Full Boost.
My partial Throttle driving normal reads 14.7-15.5 Constant.
Do these numbers sound right for a car with stock injectors and no engine management?
Isn't ideal 11.5-12.5 AFR good?
Why am I at that with no tuning lol?
Old Oct 14, 2007 | 10:29 PM
Enrique9876's Avatar
keep it in the 11's.... IMO 12.5 is a little lean ... although at 6.5 psi you shouldnt have to worry a whole heck of a lot
Old Oct 14, 2007 | 10:36 PM
yamaha16bw's Avatar
anything above 12.0 is too high for me. I run 11.4 - 11.7 all day. I idle at 14.7- 15.3
Old Oct 14, 2007 | 11:06 PM
FireStorm's Avatar
Lol mine idles at like 18+ then the guage shows the 3 ---'s b/c its idling wayyyy off hahaha.
I should be good though, Im looking to tune possibly december/January.
Old Oct 14, 2007 | 11:09 PM
Mightygnu's Avatar
When im at WOT im at 10.0 ....
Old Oct 14, 2007 | 11:14 PM
yamaha16bw's Avatar
^^^ What kind of wideband to you have? Most wont read below 10.0. WAY too rich.
Firestorm- I dont think your idle should be that off. Most factory tuned car idle right at 14.7. If you are still using the stock ecu tune then you'd think you would be right at 14.7 with or with out a turbo.
Old Oct 15, 2007 | 02:22 AM
satoman44's Avatar
could also be his sensor placement since normal driving its around 14.7.
Old Oct 15, 2007 | 03:06 AM
yamaha16bw's Avatar
Well where is your sensor welded into the exhaust?
Old Oct 16, 2007 | 12:23 AM
olaHalo's Avatar
i idle at 10.5 with the MAF sensor unplugged lol
Old Oct 16, 2007 | 12:27 AM
FireStorm's Avatar
Sensor is like.....
its right after the first bend when the pipe is on its way up and over. Its before the 2nd 02 sensor for sure by like 4 inches.
Old Oct 16, 2007 | 03:06 AM
Nu_ERA's Avatar
ScionERA
Your good with 14s and 15 chugging though town. With a 11.5 AFR at WOT you wanna stay around there but never over 12 as your leaning out
Old Oct 16, 2007 | 04:07 AM
FireStorm's Avatar
When I had the black box hooked up it was at like 10.0-10.3 partial throttle
Old Oct 16, 2007 | 05:03 AM
Mr_Meaty's Avatar
Yeah, your WOT is fine, and with tuneing, you could get your partial throttle down (i'd throw the black box back on) but your idle shoudl not be that lean. Where is it at when your cruizing around not in boost?
OH, and your running good because the ZPI kit was designed to run like that without tuning. As soon as you put an IC on or some injectors, you will need tuning.
Old Oct 16, 2007 | 05:20 AM
FireStorm's Avatar
When im just sitting still its off the scale.
When im cruising and not in boost its @ a steady 14.5-15.5
Old Oct 16, 2007 | 07:13 AM
olaHalo's Avatar
with my sensor in, (i dont have a tune yet either) i idle super lean also.
thats y i unplugged the sensor
Old Oct 16, 2007 | 03:34 PM
Mr_Meaty's Avatar
Wierd...idleing i'm right at 14.7 with the CEL on. Cruizing is about the same. you got an exhaust leak?
Old Oct 16, 2007 | 04:53 PM
FireStorm's Avatar
As a matter of fact yes I do have an exhaust leak
My CEL is one as well.
Old Oct 16, 2007 | 06:22 PM
Mr_Meaty's Avatar
Well, if your AFR sensor is in the S-pipe (like mine) and you have an exhaust leak between the S-pipe and Down pipe (like I did) then your readings arent' entirely accurate. It is reading leaner then it really is.
Depending on the severity of your exhaust leak, it may be that when your running it, there is not much of a leak cause it's pushing past, but when your ide, the exhast gases are moving slower so they are going out the leak, bypassing your AFR sensor so it reads lean. But your car will still run fine because the ECU reads the AFR from the 02 sensor in your downpipe, and there is no leak before that.
What code are you getting?
my06tc
10
Jul 13, 2015 04:13 PM
rancur3p1c
Jul 12, 2015 07:59 PM
chinito
Mar 4, 2007 03:00 PM
Prototype_xB
40
Jan 9, 2007 02:01 AM
ProshopXB
Jun 8, 2006 01:06 AM
