View Full Version : Final Edition Keyhole Covers by KEYTECHNIQUES tC,xA and xB
Pages : [1] 2 3 4 5 6 7
KEYTECHNIQUES
10-16-2007, 04:29 AM
Keyhole covers by KeyTechniques
http://i216.photobucket.com/albums/cc215/dev_r6/keyteqnique_banner-1.jpg
Please visit us @ http://keytechniques.net/Scion-Main-page.html
We have wiper plugs and bumper plugs as well
Fit and Finish
http://i216.photobucket.com/albums/cc215/dev_r6/Plug2-1.jpg
Don't be fooled by the claims of the other covers. Keytechniques keyhole covers are not plugs and the paint match is exact because we use the newer Chroma based paint and German clear coat which is UV resistant. Other paints don't match up and if you observe closely at the others you will see dispersion of the flakes and distortions in the finish and that's why we perfected the process working together with our paint supplier who is an expert in the field of paint finish. The purpose of the keyhole cover is to hide the keyhole and if the paint shade or flake is off slightly it will stand out so choose wisely and be satisfied. Bottom line is you get what you pay for from the quality of service to the packaging. There are no hidden charges or extra insurance you have to purchase as its my responsibility that you are satisfied or a refund or replacement within 15 days of your purchase.
xB keyhole covers
http://i216.photobucket.com/albums/cc215/dev_r6/Scionxbadvertisment-1.jpg
tC, xA and xB2 keyhole covers
http://i216.photobucket.com/albums/cc215/dev_r6/keyholeCoverEdited_sale-1.jpg
Each cover will be modified to fit and will be individually tested before they are painted to OEM colors and shipped out.
Ordering
Attention as of September 8th 2010 we have made ordering very easy.
Please visit our website.
Instructions on using your Keyhole covers
Warning
* Your keyhole covers are not colored plastic they are painted so please treat them with care and don't manhandle them
Mounting:
The covers consist of two parts.
1. Cover
2. Stem
tC type covers:
http://i3.photobucket.com/albums/y99/foxhokage/instructions_tC.jpg
The stem on the tC cover comes with a thin coat of contact cement to roughen up the stem and add tension to it. Observe the diagram closely to figure out the orientation of the eccentric stem to the door lock and insert the cover by stabbing it downwards and pushing the stem into the keyhole, then move it around until it is flush as can be. You will notice that the cover goes only one way due to the eccentric stem. If it does not go in on the first try changing the angle until it goes in but don't be rough with it. Remember that you will not get it to be absolutely flush due to the irregular thickness around the hole but you will find that it comes within acceptable range.
xB covers:
Not much work here but you can insert the cover as is first to check that it goes all the way in. If it doesn’t sit flush then turn it 180 degrees and reinsert the cover the right way It will sit relatively flush and look good but if you are very picky and look down from the very top with your face pressed against the door you may find an ever so small micro gap on one if the adjoining edges and I would not worry about it as it should not be visible as no one can see it.
Additional step for both covers:
Both covers should fit relatively snug but it is best to remove the cover after you have them seated well and add a small bead of contact cement on the stem, Wait 10 minutes then insert them into place. The contact cement only touches the hinged door in one small area on the out side of the lock and the rest is floating on the inside and touches nothing. This will insure that no one can easily remove the cover or any chance of it falling out. I recommend this step to ensure your satisfaction. Contact Cement is a low tension adhesive which is water resistant available at any automotive or hardware store for under $2.00. Please only use this adhesive and not a stronger one.
Removal:
You will need to first push the cover down and insert your driver’s license or credit car through the gap and fish it out. the adhesive point on the lock hinge stretches and the cover is free to come out.
Reinsertion:
Take a Q-tip doused in Alcohol and clean the adhesion point on the out side of the lock hinge which dissolves easily and replete the procedure.
The adhesion method is non destructive and can be cleaned up easy with any solvent.
*Your covers use some of the best materials for manufacture including a UV resistant clear coat which is special ordered from Germany.
Treat your covers well and it will give you many years of good service
Personal note: I am a car enthusiast just like you and trusted on many forums for my efforts and services. Please PM me if you have any complaints or problems and I will try to respond ASAP to help solve your problem.
KEYTECHNIQUES
10-16-2007, 04:31 AM
Scion Colors
tC:
SW - 040
FM - 1E0
SSM - 1E7
CSM - 1F7
BSP - 209
AP - 8Q6
BCP - 3P2
IIP - 8P4
NBM - 8S6
new color: sizzlin crimson mica 3R0
RS tCs
rs1.0 - 3P0
rs2.0 - 8Q1
xB (colors not already mentioned by tC)
BOP - 8P8
camo - 6M7
PW - 068
TCM - 1D2
SRP (salsa red) - 3Q3
shadow mica - 1F4
Gold rush Mica 580
RS xBs
rs1.0 - 4R8
rs2.0 - 576
rs3.0 - 6U1
rs4.0 - 3R2
If you don't find the color that you need please check the list below as I have a variety of Toyota colors.
Pontiac vibe and Toyota matrix colors.
Vibe colors
2003 Vibe Paint colors
19U/WA546G Abyss
81U/WA917K Lava
62U/WA916K Neptune
15U/WA914K Shadow
13U/WA891K Satellite
40U/WA9737 Frosty
44U/WA721H Salsa
46U/WA915K Envy
2004 Vibe Paint colors
56/WA913L Fusion
2005 Vibe Paint colors
14U/WA303M Platinum
90U/WA238M Moonstone
2006 Vibe Paint colors
46U/WA928L Stealth
2007 Vibe Paint colors
22U/WA482P "Tacoma" (Wave) Blue
Matrix Colors
Black Sand Pearl - 209 ('03-'06)
Indigo Ink Pearl - 8P4 ('03-'06)
Phantom Grey Pearl - 1E3 ('04-'06)
Shadow Mica - 1F4 ('05-'06)
Silver Streak Mica - 1E7 ('05-'06)
Solar Yellow - 576 ('04)
Super White - 040 ('03-'06)
Lunar mist - 1C8
Radiant Red - 3R1
Moonshadow - 1E6
rs2.0 (8Q1) BlitzBlue Mica
http://i216.photobucket.com/albums/cc215/dev_r6/BlitzBlueMica1-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/BlitzBlueMica1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/BlitzBlueMica2-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/BlitzBlueMica2.jpg
Salsa red Pearl
http://i216.photobucket.com/albums/cc215/dev_r6/SalsaRedPearl1-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/SalsaRedPearl1.jpg
Indigo Inc Pearl
http://i216.photobucket.com/albums/cc215/dev_r6/matrixindigo-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/matrixindigo.jpg
Silver Streak Mica 1E7
http://i216.photobucket.com/albums/cc215/dev_r6/SilverStreakMica-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/SilverStreakMica.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/SilverStreakMica2-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/SilverStreakMica2.jpg
Polar White (068)
http://i216.photobucket.com/albums/cc215/dev_r6/068-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/068.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/0682-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/0682.jpg
RS 2.0 (576)
http://i216.photobucket.com/albums/cc215/dev_r6/576-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/576.jpg
Black Sand Pearl (209)
http://i216.photobucket.com/albums/cc215/dev_r6/BSP2-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/BSP2.jpg
RS 3.0 (6U1)
http://i216.photobucket.com/albums/cc215/dev_r6/rs32b-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/rs32b.jpg
rs4.0 (3R2)
http://i216.photobucket.com/albums/cc215/dev_r6/Photo0025_002-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/Photo0025_002.jpg
shadow mica (1F4)
http://i216.photobucket.com/albums/cc215/dev_r6/ShadowMica-1.jpg
http://i216.photobucket.com/albums/cc215/dev_r6/ShadowMica.jpg
puddlestc
10-16-2007, 04:44 AM
will you be getting paint code 08s7 for the waveline pearl tC?
KEYTECHNIQUES
10-16-2007, 04:46 AM
Only if I can get three people that would like to order in that color.
puddlestc
10-16-2007, 05:01 AM
two more people for waveline pearl please!!!!!
WAlterEgo
10-16-2007, 05:14 AM
a) 2
b) BSP 209
c) tC
payment sent.
xdejablu3x
10-16-2007, 05:15 AM
s*** im down!...a pair of FM (1E0) for the TC for 76018 please!
KEYTECHNIQUES
10-16-2007, 05:16 AM
Just a small reminder. I am making a new batch this Wednesday so please place your orders today to get them soon.
Thanks and enjoy the sale.
Dev
cz3ch
10-16-2007, 05:37 AM
qty: 1 xb2008 wiper plug
sl name; cz3ch
colorcode: BSP - 209
email/paypal: jelinek@gmail.com
rvpps2rocks
10-16-2007, 06:13 PM
ummmi have a question idk if u wanna pm about it..i want 2 tc covers but can you paint it nissan LeMans Sunset..Paint code under Nissan is A17
hawgs74
10-16-2007, 06:23 PM
cool...
KEYTECHNIQUES
10-16-2007, 08:28 PM
I dont have that color but if you like I can send you preped covers that you can paint if you are interested.
Thanks
dev
rvpps2rocks
10-17-2007, 01:01 AM
would that be a litte cheaper since its not painted?.ill ask the bodyshop that painted my car to paint it. idk how much theyll charge
xjamiex
10-17-2007, 12:01 PM
a) 2
b) BSP 209
c) tC
for 98042
pm me
hawgs74
10-17-2007, 02:19 PM
a) 2
b) BSP - 209
c) tc
72016
KEYTECHNIQUES
10-17-2007, 02:36 PM
It would be the same price. Reason being that most of the labor is in the preperation.
Thanks
dev
rvpps2rocks
10-17-2007, 04:36 PM
eh either way...im still gunna re-prep them..but thats just a personal thing. not that i dont trust you its me.
KEYTECHNIQUES
10-17-2007, 04:49 PM
Its up to you but the price remains the same unless you want to do all of the sanding.
Thanks
dev
rvpps2rocks
10-17-2007, 04:51 PM
how much unpreped then..il probably just take it preped cuz its only 15 bucks but just curious
KEYTECHNIQUES
10-17-2007, 06:09 PM
I can do $10 but there is much work to be done in terms of sanding and preperation.
jasonrs2
10-17-2007, 06:14 PM
im unable to see the pics and interested. can someone post what they look like? thanks.
KEYTECHNIQUES
10-17-2007, 08:14 PM
I fixed the pictures. Please check the first post to see them.
Thanks
dev
cubsfanjbw
10-17-2007, 09:03 PM
2 keyhole covers and a wiper plug for 04 xb camo-6M7
RS3_tC
10-17-2007, 11:15 PM
no rs3 tC love :(
KEYTECHNIQUES
10-18-2007, 03:42 AM
no rs3 tC love :(
Get me two other people to order and I will see what I can do.
Thanks
dev
rvpps2rocks
10-18-2007, 06:34 AM
are these ready to ship if so ill pick some up friday
KEYTECHNIQUES
10-18-2007, 06:39 AM
I am making them Today and they will be shipped out on Saturday.
Please place your order now so I can get you on this batch otherwise it will not be until next week Wednesday when I make them.
Thanks
dev
jamesfg49
10-18-2007, 07:11 AM
2 xb key hole covers, 1 wiper plug cover
paint code 576
05 rs 2.0 xb
puddlestc
10-18-2007, 07:21 AM
did anyone else with a waveline pearl (code 08s7) ask you about the keycovers?
stonecoldnimrod
10-18-2007, 02:50 PM
have you considered making keyhole plugs for the rear hatches? would love to get a complete set for the 3 in my xa.
KEYTECHNIQUES
10-18-2007, 03:18 PM
I dont remember. You can check the other keyhole cover thead. It might take some time to fine the request. I suggest that you go to the color specific thread on this board and ask if anyone would like keyhole covers.
Thanks
dev
KEYTECHNIQUES
10-18-2007, 03:20 PM
We are working on a solution for the Generation Vibe guys but its has not been easy.
We do have some prototypes that we are testing but we dont know for sure at this point in time but if you order the keyhole covers now I will in the future give you a discount on the rear hatch cover.
Thanks
dev
rvpps2rocks
10-18-2007, 04:34 PM
do you need the money as soon as i place it cuz like i said ill place it but i cant send money till friday
rvpps2rocks
10-18-2007, 04:40 PM
1. 1 set for the tC(2 keyhole covers)
2. Preped not painted
3. 06 tC
KEYTECHNIQUES
10-18-2007, 05:15 PM
Send me your address though PM.
Thanks
dev
KEYTECHNIQUES
10-18-2007, 06:32 PM
Ok this is it. I have sent the list to Baltimore and I am headed to our facility in the next one hour to make the covers. These should ship out on Saturday before my AutoX in the evening heat.
The next batch will be make this coming Wednesday being the 24th and the next batch might be a bi-week because of my Fathers retirement party.
So keep ordering to take advantage of the sale.
Thanks
dev
rvpps2rocks
10-18-2007, 08:29 PM
i guess i got in just in time..haha
puddlestc
10-18-2007, 10:12 PM
how much for unpainted (but primered) ones?
rvpps2rocks
10-19-2007, 01:12 AM
same price he said
blitztc06
10-19-2007, 01:38 AM
i see there are 2 styles smooth and the other sticks out, is that just the difference between xB and tC?
KEYTECHNIQUES
10-19-2007, 06:11 AM
Yes thats right.
The xB covers don't really stick out, Its beveled on the edges to give it a smooth transition that blends into the handle. Its much better because it does not show a circular demarcation. You have to see it in person because pictures don't do it justice.
The tC covers are smooth.
KEYTECHNIQUES
10-19-2007, 06:14 AM
I just finish todays batch. We invested in a dehumidifier and it has paid off.
The covers look better then ever. The covers will ship out this Saturday after they cure.
blitztc06
10-19-2007, 06:18 AM
a) 1 set
b) 8q1 (tC RS 2.0)
c) 2006 Scion tC RS 2.0
ChelsDS
10-19-2007, 07:29 AM
Any plans on making some for the xD's? I'd be interested in getting some in Silver Streak Mica for my xD.
KEYTECHNIQUES
10-19-2007, 02:58 PM
If im not mistaken I think the xD may have the same handle as the tC.
How would you like to be my first tester. You will get a free pair.
Thanks
dev
ChelsDS
10-19-2007, 04:56 PM
Sure I wouldn't mind. No chances on scraping the paint that is already on the handle is there?
KEYTECHNIQUES
10-19-2007, 05:22 PM
Absolutly not. Go to this thead and follow directions for installation.
http://www.scionlife.com/forums/viewtopic.php?t=151189&highlight=&sid=478a691768f72ca8ce949c7bfa2a45bc
The adhisive that is used is non distructive to paint or for that matter anthing. So many on this boad never had a problem with this method so dont worry about your new xD as I understand your concern. If it did I would have been out of busness a long time ago.
Anyway being a tester I will need you to take a picture of your xD from a distance to fill the full frame and one close up on the keyhole cover with the handle.
If you are ok with this then send me your address and I will have it out to you on the next batch.
Thanks
dev
blitztc06
10-19-2007, 05:41 PM
so how do u install them? is it like the picture, just insert like a key?
KEYTECHNIQUES
10-19-2007, 05:51 PM
Go to the original post here, I have instructions for installation.
Basically you will be inserting them like a key but for the tC it only goes in one way.
You will need some rubber cement to add to the steam to make sure it does not come out.
All the directions are given in the link I provided you.
Thanks
dev
jamesfg49
10-21-2007, 07:13 PM
I am stoked!!!!!!!! :rolling: :crazy:
xjamiex
10-21-2007, 07:42 PM
Do we get a tracking number for this kind of order?
blitztc06
10-21-2007, 08:00 PM
hey i sent my paypal and havent gotten any confirmation from you guys about shipping or anything, get back to me asap
jamesfg49
10-21-2007, 08:14 PM
Patience Grasshoppers. :tap:
10/18/07.....I just finish todays batch......The covers will ship out this Saturday after they cure.
Buy them books and they eat the pages....................
rvpps2rocks
10-21-2007, 08:45 PM
sry it took 2 extra days but i just sent payment for
3. 06 tC
please send tracking number
i used my paypal account so the address on there is correct
KEYTECHNIQUES
10-22-2007, 04:36 AM
No simply because they are sent out first class mail.
Thanks
dev
KEYTECHNIQUES
10-22-2007, 04:41 AM
I usually dont send out conformations. If you would like to know the status of your order you can do so at anytime by PMing me your zipcode and I will let you know the status of your order.
For you information, I am making the next batch this Wednesday and it will be sent out on Friday.
Thanks
dev
curtislo9
10-22-2007, 04:45 AM
Man I wish I could get a sweet deal like that xD guy =P
KEYTECHNIQUES
3. 06 tC
Thanks for payment. Like I said first class mail does not have a tracking number.
Just be assured that your order will go out.
I am sorry that I cannot give each person individual conformation but if you PM me your zip I can give you a status.
In the end I work fast and hard for your satisfaction.
Thanks
dev
rvpps2rocks
10-22-2007, 05:29 AM
yea i didnt read the post about tracking.. can i get the expected delivery date...or how long it takes to ship to 93063
KEYTECHNIQUES
10-22-2007, 05:54 AM
Well I can tell you that the next batch is going to be made on Wednesday and it should ship out on Friday after the covers cure.
The Transit time after that is not relitive on location because they are sent by air.
If you are in a city or big town then you will get them within 3 busness days.
Small towns a little longer.
Thanks
dev
rvpps2rocks
10-22-2007, 05:33 PM
can you pm me so i know you got the money i sent
KEYTECHNIQUES
10-22-2007, 07:48 PM
Yes I have your order. It will be made on Wednesday and sent out Friday.
thanks
dev
WAlterEgo
10-22-2007, 08:08 PM
ordered the 15th, received today. thanks!
nice packaging btw.
edit: package was shipped on the 20th (according to the postage)
jamesfg49
10-23-2007, 03:15 AM
Dev,
All I can say is :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
Got them today. Gonna rip out my rear wiper tonight!
Thanks for a great product, near perfect color match and lighting fast shipping!
ahbo91
10-23-2007, 03:36 AM
a) 1 set
b) 3p0
c) scion tc rs1
Superpickel
10-23-2007, 03:41 AM
a) 2 plugs
b) NBM8S6
c) 07 tC
KEYTECHNIQUES
10-23-2007, 04:56 AM
Dev,
Thanks great. I have had many problems trying to get the color match just right for that color when I first starting doing it for the MR2 Spyders.
Here is a little tip if you ever have to do any touchup work. Use some white paint after the primer and then paint it Yellow.
Anyway I am please you like the covers and I woul like to see a picture of the wiper plug becaue you are the first Yellow wiper plug I have made out of the many including the Celicas.
Thanks
dev
RnB180
10-23-2007, 08:10 AM
can we see pics of the new design and installed pics on a tc?
thanks a bunch.
dugzilla
10-23-2007, 12:53 PM
a) 2 (1 set) keyhole covers and 1 wiper plug
b) 8P8
c) xb
Paypal sent for $26
KEYTECHNIQUES
10-23-2007, 03:37 PM
thanks a bunch.
It actually looks exactly like the original in pictures. The changes were made in the Paint finishing so they look better better and they hold up much better in terms of crack resistance.
Thanks
dev
KEYTECHNIQUES
10-23-2007, 05:37 PM
This is the last day to place your orders for the Wednesday batch.
Please do so now so I can make my list for the orders to be done.
Thanks
dev
spng-bxb
10-23-2007, 06:24 PM
Are they reversible? I mean, can i take them out if i choose? If so Ill take a set.
KEYTECHNIQUES
10-23-2007, 07:35 PM
Yes you can without any damage. If you want to remove them then you should push up on the cover, place a drivers licence under it and pop it out.
This makes it possible if you lose your key fob and need to open your doors in an emergency. Then you can just pop them back in as before.
Thanks
dev
spng-bxb
10-23-2007, 07:55 PM
Payment Sent, Can you let me know you got it?
1 set (2) for XB painted BCP (3P2)
rvpps2rocks
10-24-2007, 06:59 AM
got mine today taking it to the paint shop tomrrow...will post pics
im stoked good seller btw and fast shipping. Shipped saturday came in mail today which is tuesday
KEYTECHNIQUES
10-24-2007, 04:01 PM
Yes I have your order and it will be made today along with the others on this batch.
Thanks
dev
dugzilla
10-24-2007, 04:04 PM
I am assuming you got mine?
Thanks
KEYTECHNIQUES
10-24-2007, 05:41 PM
Thanks
Yes I have your order as well.
I am now sending the orders to our Baltimore location to get processed.
Thanks
dev
rvpps2rocks
10-24-2007, 11:18 PM
i took mine to get painted today...told to pick them up tomorrom ill get pics up soon
KEYTECHNIQUES
10-25-2007, 06:21 AM
That sounds great.
Thanks
dev
KEYTECHNIQUES
10-25-2007, 06:22 AM
I just finished making todays batch. It should ship out on Friday.
There are just two more sessions before I go on vacation so please take advantage of this sale before its over.
Thanks
dev
rvpps2rocks
10-26-2007, 02:04 AM
as much as i wanna say crappy cell phone pic it was the user...i forgot to change the resolution to high but heres progress
http://farm3.static.flickr.com/2253/1752043443_65a0d17016.jpg
http://farm3.static.flickr.com/2400/1752043401_d6361f17d4.jpg
anyways i should get em back tomorrow...he just wanted another day for everything to dry
KEYTECHNIQUES
10-26-2007, 02:06 AM
That looks great. I can wait to see more pictures.
Thanks
dev
rvpps2rocks
10-26-2007, 02:27 AM
thanks
xjamiex
10-26-2007, 03:06 AM
how do we know when we get it? i think i ordered mines last week
KEYTECHNIQUES
10-26-2007, 03:59 AM
They have been packed and will ship out Friday.
You should recieve it by Wednesday of next week.
Thanks
dev
rvpps2rocks
10-27-2007, 02:43 AM
Alright well heres picks my only concern is the actually come out with my fingers farely easily i mean u have to play with it a bit but its not that hard..but im scared its gunna pop out or shift while im driving...is there anything i can use to help maybe keep it in there better.
the other thing is i thought they would sit more flush. they only go in one way so is there something i can do i tryed to round the inside edge a lil bit that sort of helped and i took off a lil bit off the ends like 1/2 a mm or so and that helped but idk what else to try without going more
http://farm3.static.flickr.com/2078/1767667408_6cbdb65514.jpg
http://farm3.static.flickr.com/2105/1767667406_2ed4621dff.jpg
http://farm3.static.flickr.com/2310/1767667414_aaba6e9d6a.jpg
http://farm3.static.flickr.com/2157/1767667412_6278e7e2a2.jpg
http://farm3.static.flickr.com/2068/1767667410_f061310124.jpg
gmf
10-27-2007, 03:26 AM
a) Quantity - 1 set
b) PAINT CODE - 1F7
c) Car Make - Scion tC
85374
triniosito
10-27-2007, 07:50 AM
a) 2
b) BSP 209
c) tC
32808
Payment Sent
Dakine
10-27-2007, 08:45 AM
hey dev, any updates on como's batch? haha
fawlkin
10-27-2007, 01:24 PM
a) 2 key hole covers and 1 wiper plug
b) 6m7
c) xb
Payment sent
Lil_Deuce_tCoupe
10-27-2007, 03:27 PM
a) 1 pair
b) 1EO (Flint Mica)
c) 05 tC
Payment sent - thanks!
mmeregildo
10-27-2007, 04:20 PM
a) 2
b) 1E0
c) 06 tc
KEYTECHNIQUES
10-27-2007, 06:11 PM
What you want to do is use some rubber cement and then insert them. They will then stay in there good and wont come out. I have the instructions listed on the original post and did not transfer them here because this is mainly a promotion for my old coustermers. Also the fitment is not exactly flush but flush as can be which is still exceptable by my testers that developed the project with me. They look great BTW.
KEYTECHNIQUES
10-27-2007, 06:20 PM
I believe yours was sent out last Friday. You should have got it by now. Let me know when you get it so I dont worry.
Thanks
dev
KEYTECHNIQUES
10-27-2007, 06:21 PM
There are only two more batches left and I will be closing down for vacation.
Please get your order in now before its too late.
Thanks
dev
Dakine
10-28-2007, 01:22 AM
havent got anything. its already saturday, about a week and today. hmmm well anywho heres a pic of the old version. http://i3.photobucket.com/albums/y80/enikad/SD530939.jpg
andino
10-28-2007, 08:38 PM
1. 1 set
2. 1e0
3. tC
Payment was just sent
slowmo923
10-29-2007, 05:18 AM
a) 1
b) PW - 068
c) xb
payment sent
Dakine
10-30-2007, 03:29 PM
Guess he went on vacation...
rvpps2rocks
10-30-2007, 04:47 PM
he said the nov 15
KEYTECHNIQUES
10-30-2007, 05:08 PM
Im not on vacation.
I will however be on vacation after the next 2 batches.
Thanks
dev
KEYTECHNIQUES
10-30-2007, 07:52 PM
I will be making the next batch Wednesday.
Please place your orders Today to get your covers early.
This is the second to the last batch.
The last batch is on the 7th of November then I will be closing shop until December 1.
Thanks
dev
Pengu56
10-30-2007, 10:56 PM
Is there anyone else getting covers for the xA?
I'm interested in one set of Phantom Gray Pearl (1E3), but it doesn't seem as if any xA owners have posted in here.
I didn't see a color chart for xAs on the first page either.
rvpps2rocks
10-31-2007, 01:14 AM
its for all cars so i would get it...and its a fairly cheap price...mine turned out good..i have had time to get them to sit a lil more flush but im happy
KEYTECHNIQUES
10-31-2007, 02:38 AM
Dont worry I have done at least 30 xAs.
I have Phantom Gray Pearl as well. If you want pictures I beleive some have posted in my original non sale thread somewhere out of 45 pages.
MrBurrito
10-31-2007, 02:44 AM
1. 1 pair
2. FM - 1E0
3. tc
Pengu56
10-31-2007, 03:27 AM
1) 1 pair of covers
2) Phantom Gray Pearl 1E3
3) Scion xA
It will take a few days to pay you though, because I need to add more funds to my PayPal account. I would expect the funds to be updated at the end of this week or early next week. Thanks!
Btw, have you thought about producing covers for the raer hatch handle? If you made some, I'd probably pick one up.
KEYTECHNIQUES
10-31-2007, 04:24 AM
1) 1 pair of covers
3) Scion xA
just make sure its before the 6th.
I did send one wiper plug out to a tester but havent heard anything back so I think it works for the xA.
You can order one if you like and if it does not fit dont worry I will take care of you.
Thanks
dev
KEYTECHNIQUES
10-31-2007, 04:26 AM
This batch is almost closed.
You have until 12PM to place your order to be on Wednesdays batch.
thanks
dev
jamesfg49
10-31-2007, 06:06 AM
Dev,
I'll take pix of mine and post tomorrow.
Thanks again, very very very happy. :bow:
KEYTECHNIQUES
10-31-2007, 03:55 PM
Dev,
Great thanks man.
Dev
KEYTECHNIQUES
10-31-2007, 03:57 PM
I am extending this batch by another day.
You have until 12PM Thursday morning to be on this batch.
GaalpwrdTc
11-01-2007, 02:14 AM
FM - 1E0
07 tC
Thanks
jkois
11-01-2007, 03:39 AM
what is the code for the 08 tc sizzlin crimson pearl. i want a set but don't know the code. anyone?
KEYTECHNIQUES
11-01-2007, 04:17 AM
Its 3R0 and I dont have the paint.
If you can get me 2 other people that want keyhole covers in this color I can purchase the paint.
CatalepsicFox
11-01-2007, 07:56 AM
Free bump for the best keyholes you can get anywhere!
stonecoldnimrod
11-01-2007, 02:30 PM
3q3
06 xa
payment sent.
anu update on the xb wiper plug for the xa. i bout a plug on ebay from a seller that used it on his box and it fit, but on my xa it kind of didn't. i had to put silicone around the edge of the plug and on the back. so if this one fits then i'm down for it.
KEYTECHNIQUES
11-01-2007, 03:10 PM
3q3
06 xa
payment sent.
Even with my plugs you will need to use silicone. Its not a problem though and all of the xB guys dont have any issues with the plugs.
Thanks
dev
spng-bxb
11-01-2007, 07:39 PM
Has mine went out yet? I know the last batch went out on the 26th but I havent received mine yet? Any update?
Thanks
blitztc06
11-01-2007, 08:16 PM
I still have not received my plugs, going on 2 weeks now ordered them 10/19 it is 11/1 now.....
KEYTECHNIQUES
11-02-2007, 04:41 AM
Thanks
What is your zip.
Thanks
dev
KEYTECHNIQUES
11-02-2007, 04:42 AM
What is your zip.
If they were lost I will re-issue new ones but I will need you to PM me an accurate address.
Thanks
dev
xjamiex
11-02-2007, 04:43 AM
yea has mines went out yet and how do we know if it goes out or not?
KEYTECHNIQUES
11-02-2007, 04:48 AM
Just post your zip and I can give you an instant update.
Thanks
dev
johnnyTCblaze
11-02-2007, 05:01 AM
a) 1 set for the tC (2 keyhole covers)
b) FM - 1E0
c) tC
for 78232
pm me on when I can expect shipment. I'll paypal you as soon as I receive pm.
Thanks!
KEYTECHNIQUES
11-02-2007, 05:51 AM
b) FM - 1E0
c) tC
for 78232
Thanks!
PM sent.
Thanks
dev
KEYTECHNIQUES
11-02-2007, 05:58 AM
The latest batch has been made and should ship out soon.
There is one more batch before I go on vacation which will be made this Wednesday and the special pricing will end as well.
Just to let you all know that I am officially on vacation the 22nd.
The reason why I am not going for a third batch is to make sure that everyone receives their orders before I leave. This is so that everyone is happy and there are no complaints or missing orders. I could not enjoy my vacation otherwise.
thanks
dev
CRUZtc8
11-02-2007, 06:21 AM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
KEYTECHNIQUES
11-02-2007, 06:24 AM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
You guys dont need to send me your zip if you are ordering.
The price is the same for all the 50 states.
Thanks
dev
xjamiex
11-02-2007, 01:11 PM
98042
spng-bxb
11-02-2007, 02:28 PM
my zip is 43130
KEYTECHNIQUES
11-02-2007, 05:07 PM
98042
Your order was sent out on the 26th. Let me know if you dont recieve your order by Saturday.
Thanks
Dev
KEYTECHNIQUES
11-02-2007, 05:08 PM
my zip is 43130
Same with yours, Let me know if you dont recieve your order by Saturday.
Thanks
Dev
dugzilla
11-02-2007, 05:13 PM
98271
KEYTECHNIQUES
11-02-2007, 05:16 PM
98271
The same with yours. Orders were sent out on the 26th. I have been having problems at my other sites as well. The post office has really let me down this time.
Dont worry just let me know if your order was not recieved by Satruday.
I will take care of everyone dont worry.
andino
11-02-2007, 11:29 PM
how bout mine to 90266?
KEYTECHNIQUES
11-03-2007, 03:39 AM
Your order has been made Yesterday and it will ship out shortly.
Thanks
dev
triniosito
11-03-2007, 04:59 AM
Has mine went out yet? My Zip Is 32808
KEYTECHNIQUES
11-03-2007, 06:19 AM
It was made on Thursday and will ship out shortly.
I may delay the shipment to Monday. I want to make sure that these packages make their distination so I am going to add better lables or what ever it takes to make sure these make it.
thanks
dev
KEYTECHNIQUES
11-03-2007, 06:25 AM
I have had a few reports of covers being delivered from the batch that was sent out on the 26th. Although the post office is very late this time I am now a bit optimistic that some of covers might make it today.
If not Please let me know.
Thanks
dev
CRUZtc8
11-03-2007, 06:02 PM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
Hey Payment sent.
Thanks !
jamesfg49
11-03-2007, 06:44 PM
Color is just a tad off but yellow is extremely hard to match :yawn: especially when you don't have the car there to match. Otherwise, I am extremely pleased with the result.
Thanks again Dev :bow:
http://i85.photobucket.com/albums/k42/tat2girl920_13/Picture084.jpg
http://i85.photobucket.com/albums/k42/tat2girl920_13/Picture082.jpg
http://i85.photobucket.com/albums/k42/tat2girl920_13/Picture.jpg
For those who haven't ordered, get off your rear and order!!!!!
dugzilla
11-03-2007, 09:33 PM
got the mail today, still no plugs :(
spng-bxb
11-03-2007, 09:41 PM
I didnt get mine either.
KEYTECHNIQUES
11-04-2007, 01:02 AM
Ok guys lets do this again.
I will need you to PM me an exact address and your order.
I will add you to the next batch of covers that is going to be made this Wednesday.
Very sorry for what happend with the post office. I think its my local post office this time screwed up. Please bear with me.
Thanks
dev
dugzilla
11-04-2007, 02:02 AM
PM'd info.
PeterParker
11-04-2007, 06:08 AM
a) 1 set keyhole covers & 1 wiper plug
b) BOP - 8P8
c) Xb
Paypal Sent for $26
junklr
11-05-2007, 12:20 AM
a) 1 Set Keyhole Cover
b) BSP - 209
c) 2005 Xb
xjamiex
11-05-2007, 12:30 AM
Have not receive mines yet 98042
KEYTECHNIQUES
11-05-2007, 02:57 AM
Please send me a pm with your address and order.
I will send it out again.
Thanks
Dev
siupo128
11-05-2007, 08:27 AM
a) 1 set
b) 040
c) scion tc 07
payment sent by paypal
KEYTECHNIQUES
11-05-2007, 02:44 PM
Two more days until I close down for the rest of this month.
Please place your orders before its too late and I go on vacation.
Last batch is going to be made Wednesday.
Thanks
dev
aalbertson3
11-05-2007, 04:59 PM
Is the sale still going on until the 15th? Was planning on ordering 2 sets this friday.......... :ponder:
KEYTECHNIQUES
11-05-2007, 05:04 PM
I am sorry, The last day to order will be Wednesday 12PM before I make the last batch. I am going on vacation and have to end the batch prematurly.
If anyone orders after Wednesday and before the 15th they will still recived the sale price but you will have to wait until I come back to make the batch which should be around the 1st of December.
Thanks
dev
jkois
11-05-2007, 06:04 PM
2 each
tc
14.00 sent paypal.
KEYTECHNIQUES
11-05-2007, 06:15 PM
2 each
tc
14.00 sent paypal.
I am sorry but I do not have that color. I will have to refund your payment unless you want unpainted ones that you can paint at a later time.
Sorry again.
Thanks
dev
jkois
11-05-2007, 06:28 PM
2 each
tc
14.00 sent paypal.
Sorry again.
Thanks
dev
Refund then, let me know if and when you will get the color. what is the color code for this color anyway???
KEYTECHNIQUES
11-05-2007, 06:44 PM
2 each
tc
14.00 sent paypal.
Sorry again.
Thanks
dev
I think it was 3R1. If you can get two others that want this color I can make it for you.
Also it will take me some time to refund your payment. It seems that paypal is not showing me the most current activity. I will get your refund to you ASAP .
Thanks
dev
Scarab23
11-05-2007, 06:59 PM
a) 2
b) 1E0
c) tC
Payment Sent ;)
jkois
11-06-2007, 01:07 AM
2 each
tc
14.00 sent paypal.
Sorry again.
Thanks
dev
Thanks
dev
come on crimson mica people, i got to have these and so do you. only 14 bucks. come on let's hear you. when is the last time you stuck your key into the lock to open your door. you know you are as lazy as me. let's hear it for crimson mica!!!!!! let's go
rvpps2rocks
11-06-2007, 01:29 AM
^^^some ones enthusiastic
andino
11-06-2007, 01:31 AM
^^ lol he wants his plugs :)
jkois
11-06-2007, 01:34 AM
i gotta be plugged
KEYTECHNIQUES
11-06-2007, 06:02 AM
I really feel for you. If you can get me just one more person to order I can possibly get the color.
However this will be done after December as I am closing the batches for the rest of this month after Wednesday.
rvpps2rocks
11-06-2007, 04:43 PM
man i really need to finish my keyholes...ill get new pics up asap and a review
mmeregildo
11-06-2007, 05:17 PM
32714 just checking on an update
KEYTECHNIQUES
11-06-2007, 06:05 PM
Your order was shipped out on Monday.
You should recieve it this week.
Thanks
dev
KEYTECHNIQUES
11-06-2007, 06:30 PM
The last day to order covers.
You have until 12pm Wednesday estern time to place your order.
This is the last batch until December 1.
Lil_Deuce_tCoupe
11-06-2007, 11:50 PM
a) 1 pair
b) 1EO (Flint Mica)
c) 05 tC
I ordered these on the 27th - just want to know if they're in transit or going out before your vacation. (Shipped to 01590) Thanks.
Pengu56
11-07-2007, 12:56 AM
Hey, I just sent out $29 to you for:
a) 1 pair + I think another pair? to test if it will fit in the rear hatch key hole for the xA
b) Phantom Gray Pearl (1E3)
c) 2004 xA
KEYTECHNIQUES
11-07-2007, 01:30 AM
a) 1 pair
b) 1EO (Flint Mica)
c) 05 tC
Your order was sent out Monday and you should recieve it hopfully by Saturday.
Thanks
dev
KEYTECHNIQUES
11-07-2007, 01:37 AM
c) 2004 xA
I have your order. It is going to be made on the last batch Wednesday and should ship out this Friday.
Thanks
dev
Dakine
11-07-2007, 02:05 AM
Dev asked me to marry him!!!
http://i3.photobucket.com/albums/y80/enikad/SD530984.jpg
Left side is his old version, right side final edition. Looks a bit better!
http://i3.photobucket.com/albums/y80/enikad/SD530988.jpg
KEYTECHNIQUES
11-07-2007, 02:08 AM
Great you finally got your order.
How do you like the new boxes.
dugzilla
11-07-2007, 02:13 AM
Maybe I will still get mine in the mail? did you send his the same time as mine? I hope so.
Dakine
11-07-2007, 02:15 AM
I think dev has ask alot of guys/gals hand in marriage with this one. I love it!!! Wish the other one didnt get lost tho...
andino
11-07-2007, 02:43 AM
1. 1 set
2. 1e0
3. tC
just wondering if my order went out yet. Thanks :)
KEYTECHNIQUES
11-07-2007, 03:41 AM
1. 1 set
2. 1e0
3. tC
Your order has gone out Monday and you should recieve it by Saturday.
Thanks
dev
andino
11-07-2007, 03:43 AM
awesome thanks :)
KEYTECHNIQUES
11-07-2007, 03:46 AM
You actually have the lost one. My my my. I would check the date on the package.
The replacment was sent out Monday so its impossible for you to recieve it that early.
KEYTECHNIQUES
11-07-2007, 03:53 AM
I might have but I am not holding my breath for you guys. Enough is enough and the post office for the first time in three years has really let me down for those that are on the 26th batch on all my boards. Some made it, some were late and others did not make it at all.
I appreciate everyone on the 26th batch waiting for their replacements which are going to be made Wednesday and shipped out Friday.
It is possible that the lost ones might actually come in very late.
Dakine
11-07-2007, 04:19 AM
For everyone who hasnt recieve theirs. be patient. i got mine a week and a half and its not dev's fault. But here is my reivew for all those who have or planning to buy the new editions.
The paint on the old versions do seem nice but kinda flimsy. like there wasnt enough clear but still was a good product. but now that dev updated his paint, it feels tough and strong. i actually dropped it while install and no scratches at all! i gotta admit, dev did more of a great job on the paint job and still held the same design! No middle circle like the first and much more smoother from the side! I love it! Thanks!!!
KEYTECHNIQUES
11-07-2007, 04:47 PM
Ok I am closing off this batch.
There will be no more orders until I get back.
Actually I might start up again on the 27th of November.
Thanks
dev
aalbertson3
11-07-2007, 05:04 PM
I am still gonna order a couple sets this Friday. They will be worth the wait! :bow:
dmaul1397
11-07-2007, 05:12 PM
a) 1 Wiper Plug and 2 Keyhole Covers
b) TCM - 1D2
c) 2005 xB
KEYTECHNIQUES
11-07-2007, 05:29 PM
Just to show you I am a cool guy and I can send them out to you early.
What do you need. I am going to have them made right now and you can pay me on Friday or latter for them.
Thanks
dev
mmeregildo
just got mine in look great thanks
KEYTECHNIQUES
11-07-2007, 05:34 PM
b) TCM - 1D2
c) 2005 xB
I have you down for the last order.
You have not sent payment yet but I will have them made anyway so when you do it will ship out on the last batch.
Thanks
dev
tccurtis
11-07-2007, 07:18 PM
pm me about 2 nautica blue for 07 tc thanks..
aalbertson3
11-07-2007, 08:11 PM
Thanks
dev
That is awesome! Thank you very much......... :D
Here is what I need:
a) 2 Key hole covers
b) TCM - 1D2
c) xB
b) BSP - 209
c) xB
Will send the $22 this Friday.
CRUZtc8
11-08-2007, 08:31 PM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
Hey Payment sent.
Thanks !hey just want to know if my key holes have been shipped out? i order these this past saturday 11/3/07 60473.
KEYTECHNIQUES
11-08-2007, 09:18 PM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
Hey Payment sent.
I emailed you two days ago concerning no address provided in your paypal.
I need you to PM me your adress so I can send them out.
Thanks
dev
CRUZtc8
11-09-2007, 12:25 AM
a) 2
b) CSM-1F7
c) tC
for 60473
pm me
Hey Payment sent.
Thanks
dev hey i pm you my address, I thought you would see my address in my paypal.
CatalepsicFox
11-09-2007, 01:26 AM
^^ would be able to see the address if you had picked the option of payment of goods.... or payment option that requires shipping.
aalbertson3
11-09-2007, 06:18 PM
Thanks
dev
b) TCM - 1D2
c) xB
b) BSP - 209
c) xB
Payment sent! Thanks again Dev
teamneon
11-10-2007, 05:05 PM
a) two
b) rs1.0 - 4R8
c) XB
Paypal sent BTW
spng-bxb
11-10-2007, 09:49 PM
I havent received mine, but since you said a new batch went out this friday, ill wait some more. It allright tho, just as long as i dont get screwed over
KEYTECHNIQUES
11-10-2007, 10:03 PM
It seems that your replacment order did in fact go out Yesterday.
But more importantly even if by change you dont even recieve your order please dont think that I would ever screw you.
I have been here for over a year and I have never screwed anyone.
Thanks
dev
KEYTECHNIQUES
11-10-2007, 10:08 PM
I have room for one more batch but thats it.
I gave myself a week in reserve incase there are any problems before I go on vacation.
If you order now and when I am on vacation dont recieve your order then you will have to wait until I return on the 27th of November to have it replaced or resolved.
Your money is my primary concern and Its in good hands and at anytime you need a refund before the order is shipped out its there no questions asked.
Just please be fair with me in my absence as I know some of you can be very impatient and anxious.
Thanks
dev
teamneon
11-10-2007, 10:24 PM
i dont even have a FOB so i cant use these until i get my alarm (group buy) installed in at least a week. lol
KEYTECHNIQUES
11-10-2007, 10:52 PM
Well actually I did not want to take new orders becauase I wanted to make sure the orders before this have no issues before I go on vacation but I decided to do one last batch and you are on it.
Thanks
dev
MyBlueTwo
11-12-2007, 03:08 AM
a) 2
b) rs2.0 - 8Q1
c) tC
Payment sent
Scarab23
11-13-2007, 01:35 AM
a) 2
b) 1E0
c) tC
Payment Sent ;)
Just wondering if these shipped yet, Thanks.
KEYTECHNIQUES
11-13-2007, 01:58 AM
a) 2
b) 1E0
c) tC
Payment Sent ;)
What is you zip.
thanks
dev
KEYTECHNIQUES
11-13-2007, 02:04 AM
a) 2
b) 1E0
c) tC
Payment Sent ;)
Found your order. It has shipped out Friday. You should recieve it anyday now.
Thanks
dev
xjamiex
11-13-2007, 02:11 AM
i still have not gotten mines yet and i order from the first batch i believe about 3 or 2 weeks ago
KEYTECHNIQUES
11-13-2007, 02:16 AM
That order was re made and also shipped out Friday and you should recieve it any day now.
Thanks
dev
mavesp
11-14-2007, 12:21 AM
a) 2
b) FM - 1E0
c) tC
payment sent!
dugzilla
11-14-2007, 12:42 AM
Dev, got mine today! looks great, worth the wait.
Scarab23
11-14-2007, 01:19 AM
a) 2
b) 1E0
c) tC
Payment Sent ;)
Thanks
dev
Thanks
KEYTECHNIQUES
11-14-2007, 01:34 AM
That makes me very happy that those that had orders lost in the mail have finally recieved the second attempt. I hope everyone else gets theirs as well.
Thanks
dev
LivNLo94
11-14-2007, 04:57 AM
1 set, or 2 key hole covers
Silver Streak Mica (SSM)
2005 Scion tC
Payment sent
Thanks
spng-bxb
11-14-2007, 12:44 PM
I got mine yesterday also!!! They look great and fit good!!!
ChelsDS
11-14-2007, 06:22 PM
Oh hey I got mine in the other day for the xD, and they both don't fit flush. I'm going to take a picture and let you see.
KEYTECHNIQUES
11-14-2007, 06:43 PM
No need for pictures. The covers do not sit perfectly flush but they are acceptable.
if you are not satisfied send them back for a full refund.
Thanks
dev
dugzilla
11-14-2007, 06:59 PM
Mine fit completely flush, makes the car look complete.
KEYTECHNIQUES
11-14-2007, 07:08 PM
The xB Type covers fit flusher then the tC covers.
The tC covers are still acceptable by most although they don't sit as flush. I never had to refund an order because of the lack of flushness.
Thanks
dev
jurassic1
11-14-2007, 07:22 PM
Just ordered!
1. one pair
2. Flint Mica 1E0
3. Tc
payment sent! :)
KEYTECHNIQUES
11-15-2007, 03:56 AM
Thats it I am done until I get back from vacation. I have made the last batch of covers.
If you would like to order you can do so but the covers will not be made until I get back from vacation.
As an incentive I have extended the sale in my absence so please take advantage of it before I come back and raise the price.
Thanks
dev
jkois
11-15-2007, 02:29 PM
can we get some sizzlin crimson mica for the 08 tc yet? come on people, don't make me buy 3 sets myself!!!!
stonecoldnimrod
11-16-2007, 07:32 PM
yo can you tell me where mine are. i ordered them 2 weeks ago shipped to 77009. thanks.
KEYTECHNIQUES
11-17-2007, 01:37 AM
I am very sorry you did not recieve your order. My records indicate that it shipped out on the 5th of this month. It might be late. Lets give it until Monday evening and if it does not come in I will take care of you.
Thanks
dev
CRUZtc8
11-17-2007, 01:45 AM
hey have my keyholes been shipped 60473?? its almost been 2 weeks.
KEYTECHNIQUES
11-17-2007, 01:50 AM
Yours has been send on the 5th as well. Lets give it until Monday evening.
Thanks
dev
Imperial
11-17-2007, 01:58 AM
Still not offering Blizzard Pearl for the tC RS 3.0?
KEYTECHNIQUES
11-17-2007, 02:03 AM
I would love to carry that color. It is not cheap as I looked into it because its a Tri-coat. My paint suplier said he can get an exact match.
If you can get me two more people I can make it happen.
tc913
11-19-2007, 01:52 AM
1) 2 key hole covers
2) SW 040
3) tC
Payment sent!
Scarab23
11-19-2007, 06:33 PM
Got mine, thank you!!
Look Great!
Dakine
11-19-2007, 06:40 PM
^Congrats Scarab. AND HAPPY BIRTHDAY!!!
Scarab23
11-19-2007, 09:04 PM
Ah, Thanks Dak ;)
CRUZtc8
11-20-2007, 12:28 AM
hey got mine today but still need to put them on this weekend.
jurassic1
11-20-2007, 01:29 AM
got mine too! that was fast shipping lol! nweiz, can't wait to put it on my car (after a much needed carwash of course)---as a finishing touch! thanks dev!
KEYTECHNIQUES
11-20-2007, 01:45 AM
It great to see that many have got their orders.
I will be passing on the admin work of answering your responces on Wednesday to;
Dakine and CatalepsicFox
They will answer any questions in my absence so if you did not recieved an order please dont freak out. When I get back into the country I will take care of you either by refund or re--order if you like.
As allways your money is good as being in a bank so dont worry about a thing.
Thanks
dev
LivNLo94
11-20-2007, 04:35 AM
got mine today, damn that was fast...........thanks
stonecoldnimrod
11-20-2007, 01:39 PM
hey yo i just got em!!! crappy houston weather tho. i'll post pics before the end of the week. they came in a box... they look like cufflinks.
KEYTECHNIQUES
11-20-2007, 02:07 PM
Great. I will be most happy when everyone gets their orders before I go.
It would spoil my vacation knowing that somone did not get their order.
Thanks
dev
aalbertson3
11-20-2007, 03:54 PM
Both of my sets came in yesterday! Another crazy looking shipping method........... :bow:
MyBlueTwo
11-24-2007, 09:21 AM
BUMP for a great product, got mine in the mail super fast and they look great on my car. Perfect color match.
Dakine
11-24-2007, 06:23 PM
Glad to hear aalbertson3 and MyBlueTwo!!! Anyone else gets theirs?
jurassic1
11-25-2007, 12:06 AM
I got mine last week and I just put it on my car today after I washed it-----great improvement! Perfectly color-matched to my FM! Very satisfied with them. Now my car's more aerodynamic! :P LOL! Thanks Dev!
Vince
11-25-2007, 05:06 PM
1) 2 xB keyhole covers & 1 xB wiper plug
2) 8P8
3) Scion xB
$26.00 payment sent via PayPal.
Thanks!
Dakine
11-25-2007, 06:42 PM
Hey vince, Dev will be on vacation till the 27th but ur keyholes will be made on the 5th of Dec. Please be patient.
Anyone else who wants to order you can still take advantage of the sale!
Vince
11-25-2007, 11:34 PM
No problem. I probably won't do the install until spring, but wanted to take advantage of the sale. Thanks again!
tintin
11-26-2007, 08:22 PM
I didn't realize the sale was extended until the 27th
and I placed an order in the old thread on 11/17/07 for
Quantity: 1 set (2 plugs) Keyhole covers
Paint Code: PW - 068
Vehicle model: 06 Scion xB
and i I paid $14 on the same day.
Please tell me what to do.
Thanks
Dakine
11-26-2007, 09:27 PM
I will email dev about ur issue tintin. please be patient, i will update on you about what we can do.
Thanks.
Upstate-Bay6
11-27-2007, 03:56 AM
i want 2, $15 shipped for 1 xB wiper plug.
colors:
BOP - 8P8
shadow mica - 1F4
get back to me about paypal cuz i dont know where to send to
Models
BOP 2006 SCION XB
Shawdow Mica 2006 Scion XB
Upstate-Bay6
11-27-2007, 04:08 AM
nevermind i just sent payment
curtislo9
11-27-2007, 06:26 AM
i want:
-1 set of key hole covers
-(FM) 1E0
-Scion Tc 2007
Dakine
11-28-2007, 07:18 PM
Bump! Thanks for ur order curtislo9
