tommitls
10-22-2007, 02:26 AM
hey all,
whats the average tire life for a 19" wheel size...235/25/19
i know the stock tC only lasted about 25k before i had to get rid of them...should these be even less?
captainlaziness
10-22-2007, 02:53 AM
That depends on various factors including driving style, road conditions, and mainly the treadwear rating on the tire of your choice.
tommitls
10-22-2007, 04:08 AM
hmm...i commute 100 miles a day on average, mostly highway, the tires are z-rated..., kumho spts
i don't race or anything...normal ddriving but extended since i travel far...mainly highways once again
captainlaziness
10-22-2007, 05:06 AM
The treadwear rating on those tires is 320 and the OE tires (both Bridgestone and Yokohama) carry a rating of 160. So they should last longer but;
Treadwear Grades
UTQG Treadwear Grades are based on actual road use in which the test tire is run in a vehicle convoy along with standardized Course Monitoring Tires. The vehicle repeatedly runs a prescribed 400-mile test loop in West Texas for a total of 7,200 miles. The vehicle can have its alignment set, air pressure checked and tires rotated every 800 miles. The test tire's and the Monitoring Tire's wear are measured during and at the conclusion of the test. The tire manufacturers then assign a Treadwear Grade based on the observed wear rates. The Course Monitoring Tire is assigned a grade and the test tire receives a grade indicating its relative treadwear. A grade of 100 would indicate that the tire tread would last as long as the test tire, 200 would indicate the tread would last twice as long, 300 would indicate three times as long, etc.
The problem with UTQG Treadwear Grades is that they are open to some interpretation on the part of the tire manufacturer because they are assigned after the tire has only experienced a little treadwear as it runs the 7,200 miles. This means that the tire manufacturers need to extrapolate their raw wear data when they are assigning Treadwear Grades, and that their grades can to some extent reflect how conservative or optimistic their marketing department is. Typically, comparing the Treadwear Grades of tire lines within a single brand is somewhat helpful, while attempting to compare the grades between different brands is not as helpful.
From www.tirerack.com
