Better Gas Mileage?
Old Oct 22, 2007 | 11:53 AM
JCM900's Avatar
Default Better Gas Mileage?
how can i get better gas mileage for my tC....... i heard a cai might help
Old Oct 22, 2007 | 02:33 PM
locondcoco's Avatar
a CAI has certainly helped me (about a 1.5-2 mpg increase).
others have said it actually DECREASES your MPG. i think its because it sounds cool, and you just wanna get on it to hear more...
honestly, the best improvement in gas mileage is driving style (ie- easy on the gas as you're accelerating, staying under...65, 70mph, try to coast if you see traffic slowing ahead of you...etc)
Old Oct 22, 2007 | 02:39 PM
GarmaZed's Avatar
I get atleast 27 MPG in my daily driving, and I'm able to extend that up to 30 whenever I want to by changing how I drive. Mine is a stock 5-speed.
What is it you are getting?
Old Oct 22, 2007 | 04:58 PM
Scott8's Avatar
I have heard if you take the snorkel piece off the stock intake it helps to get a few more miles per gallon.
but driving habits is the key to better mileage
Old Oct 22, 2007 | 09:15 PM
malibuboy54's Avatar
don't have such a heavy foot.....for street driving, 2500-3000 rpm and shift gears usually gets you to normal road speeds.....now if you're one to romp on it and go 4000+ rpm every shift, then i would say you're driving too hard for daily driving, unless you need that extra power to get onto the freeway, etc....lol
Old Oct 22, 2007 | 09:28 PM
CuRiOuSfIsH's Avatar
other than the things already mentioned, you can over inflate the tires a little.....
things not to do is MOD. Keep things stock...... unless youre removing pieces to save weight.
Old Oct 24, 2007 | 03:12 PM
DriveEuro's Avatar
Best way is driving habit. I almost always shift at 3000rpm (+/- 250rpm). This help dramatically. Sure, it isn't necessarily as fun to drive like this since you're not making so much power... But when you save 2-4mpg on each tank of gas it will add up in the end.
Old Oct 24, 2007 | 04:15 PM
puddlestc's Avatar
I thought any/all intakes or air filters help increase MPG due to the air filter material being foam rather than the paper one that comes stock with the car? or does it also have to deal with the driving style after the intake is installed?
Old Oct 24, 2007 | 04:18 PM
locondcoco's Avatar
well, i think the idea is,
CAI = colder air = more O2 in the air = more fuel required to burn that O2 = less mpg. but like i said, i've seen a vast improvement since i had it installed.
Old Oct 24, 2007 | 04:50 PM
monkeysauce's Avatar
Generally speaking, warm air into the engine = better mileage
Old Oct 24, 2007 | 06:09 PM
DriveEuro's Avatar
Right, that's why you get worse gas mileage in the winter (at least I do). In my tC I see 2-3mpg worse in the winter than I do in the summer/spring/fall. It was MUCH more noticeable when I drove a Ford Ranger. In the winter I would get 3-5mpg worse than in warmer times of the year.
Old Oct 24, 2007 | 06:19 PM
Depending on where you live, they also add ethanol to the gas in the winter to prevent water condensation. This alone can drop your mileage.
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Nov 20, 2015 06:56 PM
mudguy
Oct 22, 2015 04:31 PM
prescottn
Sep 22, 2015 01:30 PM
BlingSlade
Sep 5, 2015 08:52 AM
