View Full Version : HID Problems please help
samos
10-26-2007, 03:18 AM
Ok so ive searched and visited all the hid headlight problem topics and cant seem to find a straight away answer to my problems. Both of my head lights are out. at one time one went out briefly while i was driving but then came back on and had been fine until the other morning when i turned my car on and no lights. Ive re connected basically every wire and checked the fuses in the fuse box, none blown
Any suggestions? or answers?
Yanki01
10-26-2007, 03:20 AM
probally one of those "you get what you paid for" deals right about now i would think? Bad wires, ballast, bulbs....? Got warranty on it?
amdforever
10-26-2007, 03:25 AM
Does the ballast plug directly into the stock car harness? If so, look at as much as possible of the stock harness and see if it burned itself up.
BZinn1
10-26-2007, 04:26 AM
^^^^Look for damage.........test with meter to se if you have power to ballasts......if you do.........then ballasts can be toast......check with meter fro power after ballasts........if you do then bulbs are toast...........but my guess is ballasts first.....or harness........and never buy anything cheap fro your car ..........what kit...........perhaps we can figure out what is fried.......but sounds like balast.....
amdforever
10-26-2007, 04:36 AM
did you check both fuse boxes? I dont have my tC to go look for you but just wondering if you checked both. the odd thing is only one went out and then after a period both just went out.
Viace
10-26-2007, 04:37 AM
upgrade your fuses
samos
10-27-2007, 04:16 AM
working on checking these things i guess ill get back to you tomoro thanks alot
samos
10-27-2007, 02:21 PM
it appears i have power going into the balast and basically none coming out.. so a blown balast?
striker_1818
10-27-2007, 04:43 PM
hook them up directly to the battery.
If that doesn't work, then you know for a fact your ballast is blown.
but BE CAREFUL!
cliffud
10-28-2007, 04:06 AM
samos-
Please check out the installation instructions on my site and make sure you ground to the battery and check out the troubleshooting steps.
Thanks.
http://www.mobilehid.com/support.htm
Clifford
taco
10-28-2007, 11:58 PM
upgrade your fuses
never upgrade fuses, fuse are there so u dont get a fire.
make a harness would of been a better awnser.
or kit suck and blind everyone. retro ftw!
