Noise While Driving....HELPPP
Old Oct 30, 2007 | 01:56 PM
rosedaleny806's Avatar
Default Noise While Driving....HELPPP
so i come to realize the past couple of weeks my tc has been making a weird nopise when i drive...it sound slike its coming from the tires in the rear, it has like thumping not hard but it sound slike there would be a bald spot on the tires in the back...i pu tmy car in neutral and jus let it roll to hear it and its coming from the back but i checked my tires and theres no bald spot so i was wondering wat it can be maybe an alignment? and i also felt like my steering wheel vibrates alot on turns and the car feels weird on turns too PLEASE HELPP GUYS if any 1 can
Old Oct 30, 2007 | 01:57 PM
any1? lol
Old Oct 30, 2007 | 02:05 PM
Enrique9876's Avatar
do you yank the e brake often? that could cause a flat spot. id get them balanced AND aligned ... if you feel vibrations in your seat it usually means your rear tires are out of balance and if you feel vibrations in your steering wheel it usually means your fronts are out of balance. thats just a rule of thumb though
Old Oct 30, 2007 | 02:08 PM
locondcoco's Avatar
it may simply be time for new tires, how many miles are on your current tires? i see you have an 05 still on stock tires. (unless you just haven't updated). but i would check your treads to see how much you have left.
i recently had all types of vibration, rumble, etc...then i realized i was all the way down to the wearbar on the stock tires at 36k.
Old Oct 30, 2007 | 02:17 PM
HunterGreene's Avatar
Possibly brake rotors? Vibration through the steering wheel would be a telltale sign, not sure about the vibrating from the back. Wouldnt hurt to have that looked at while they have the wheels off
Old Oct 30, 2007 | 02:19 PM
nope i never yank the ebrake at all actually and i noticed that my steering wheel is alil to the right and the car moves straight so basically even thought the car drives forward fine the steering wheel is slightly to the right....i changed my front tires but not the back cause they said those were still fine i got the front ones balanced but not aligned should i jus go get a wheel alignment?
Old Oct 30, 2007 | 02:29 PM
yup get them aligned and balanced ... consider changing the rear tires while ur at it....
Old Oct 30, 2007 | 02:42 PM
so u think thats all it is? that i jus need an alignment and balance plus 2 new bak tires?
Old Oct 30, 2007 | 02:44 PM
yea thats what i think BUT a professional tire place will be able to tell you better
Old Oct 30, 2007 | 03:01 PM
hopefully thats it, i dont think its anything serious its jus annoying hearing that noise
Old Oct 30, 2007 | 03:27 PM
GarmaZed's Avatar
Hold your tire up to the monitor so I can feel them. That's as best of a job as we can do. :\
Old Oct 30, 2007 | 03:29 PM
^^^ hehe...if only.
Old Oct 30, 2007 | 03:44 PM
haha i wish
Old Oct 30, 2007 | 03:58 PM
2007_wichitaSCION's Avatar
this might be far off from the problem but make sure that everything is ok and not damaged from like a rock or stick hitting it and check all the bolts and such to make sure that everything is tight and still there
Old Oct 30, 2007 | 04:21 PM
chaseonbass's Avatar
Bent rim?
Old Oct 30, 2007 | 05:19 PM
yeah i checked it again today everything seems fine tires dont have a flat spot bent rim isnt visible but maybe it might be bent NYC is the worst to drive in so i dunno im gonna try getting an alignment and check to see if thats it ill keep u guys informed thanx
Old Oct 31, 2007 | 12:21 AM
sciontc_mich's Avatar
tell the mechanic to get the fronts to 0.0" or 0.0 degrees of toe, you'll thank me. rears should be 0.12-0.15degrees of toe.
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
alexbarspin
Sep 3, 2015 02:04 AM
