Catalistic
Old Oct 30, 2007 | 06:55 PM
Boy-Xa's Avatar
Default Catalistic
How much HP I get if I removed the cat and the resonator???
Old Oct 31, 2007 | 12:25 AM
jct's Avatar
jct
zero
Old Oct 31, 2007 | 12:27 AM
jallamas's Avatar
Not sure where you are from but out here in CA it's illegal as hell.
John
Old Oct 31, 2007 | 01:52 AM
low_down_xb's Avatar
Originally Posted by duck_dodgers_24_5
zero
you got it!! not worth the check engine light that will annoy the sh*t out of you, and its not legal, wont pass emisionstestif you have it, but it will be loud as crap andmost run very poorly
Old Oct 31, 2007 | 04:40 PM
JSosa's Avatar
not worth it, dont do it!
Old Nov 1, 2007 | 02:18 AM
D_M_A_N's Avatar
errr... is that how you spell it?
Old Nov 1, 2007 | 02:34 AM
Jan06xB's Avatar
The O2 sensors will drive the ECU crazy with the air fuel mixture adjustments without the cat reaction.
Old Nov 1, 2007 | 06:23 PM
itsme's Avatar
the cost of paying fines isnt worth 1hp from removing the cat........your better off keeping it on......i think there was a comparison in Import Tuner about cats and straight pipes and there was like a 1hp gain out of the straight pipe which isnt really worth it IMHO
Old Nov 2, 2007 | 06:22 PM
Boy-Xa's Avatar
Default OK
Souuu what you people recomended to me???? High flow cat!! That cost like $$100.00.. I have a Intake,portenciometer and tricks....But I want more WHP but I dont want any NOS & Turbo....
Old Nov 2, 2007 | 10:30 PM
taking the cat offwont do crapfor your power needs, what is a portenciometer and tricks? andwhatdid that do for your power? but ifyour looking for more power maybeyou should have just bought a tc or something
Old Nov 2, 2007 | 11:32 PM
Distracted_Thinker's Avatar
well in some places you dont have to pass emissions. The county im registered in doesnt require me to. Also there is a dummy sensor that you can buy for around 20 dollars that keeps your computer going crazy.
Old Nov 3, 2007 | 01:23 AM
Jan06xB's Avatar
Ideally you would want a new A/F map so that it gets richer at wider throttle openings and normal to a little lean at light throttle openings to make up for the wasted gas at richer settings. Getting the A/F ratio in teh 12 range yields about 20% more power than at the 16-18 to 1 range where you get max economy. A better tuned exhaust for higher RPM's will also help maybe a better header although the stock one is pretty good. Some guys are running low shots of dry NOS with good results and plenty of reliable miles on their systems - approaching 100k miles. Getting more fuel and air into the engine and making it burn faster are the only way to make more power.
Old Nov 3, 2007 | 05:25 AM
Gothbox's Avatar
so whee would I go to look for one of these new A/F maps? sounds like this is what I need.
Old Nov 5, 2007 | 01:33 PM
Boy-Xa's Avatar
Default OK
A potenciometer confuse the ecu and send more gas to the engine....And trick, is that I eliminate the trothel hoses that old....
Old Nov 5, 2007 | 06:00 PM
Default Re: OK
all you did was confuse me even more, what is a trothel, and "that old....."?
Old Nov 5, 2007 | 06:15 PM
Jan06xB's Avatar
You can change the O2 sensor feedback and get an over all richer mixture but you want to tailor the A/F mixture differently so that you want rich at full throttle HIGH RPM only and normal to a little lean at other light throttle positions. Usually it requires a "Black Box" connected in line with the sensors and injectors to modify what the ECU sees and does to what you want it to see and do . . . run richer. Search the Turbo threads for what they use.
redwar1441
14
Jan 29, 2007 08:59 PM
Fastscion
Jan 29, 2006 07:39 PM
