Problem with Hotchkis strut tower bar (beware: big pics)
Old Oct 26, 2004 | 01:55 PM
crawfordna's Avatar
Default Problem with Hotchkis strut tower bar (beware: big pics)
Hi guys,
Got a tC, tried to install strut tower bar last night. When I was finishing everything up, I torqued the end plates down to 59ft-lbs as indicated in the manual. I don't think the end plates can handle this amount of torque, the bolts basically cut right through the plates. Trying to figure out if I did something wrong or if I have a faulty set of plates.
--Nick
Old Oct 26, 2004 | 03:17 PM
DJ_X_Trodinaire's Avatar
ouch!
looks like it needed some washers?
Old Oct 26, 2004 | 03:24 PM
crawfordna's Avatar
Didn't come with any and not indicated in the instructions... I'm thinking just a cheap piece of metal or a bad batch. I checked my torque wrench to see if it was accurate and it is in perfect calibration (good ol Craftsman.)
--Nick
Old Oct 26, 2004 | 04:34 PM
JasonH's Avatar
My manual says 38 ft-lbs for the 3 nuts on the top of the struts. That's where it attaches, right? Where did you get 59 ft-lbs?
Old Oct 26, 2004 | 04:46 PM
superjeer's Avatar
that sucks.. and I think shows how much those help Soft steel, or maybe pasta...
Old Oct 26, 2004 | 04:51 PM
JasonH's Avatar
Okay, I see in the instructions for the bar it does say 59 ft-lbs. Maybe it's wrong? Are you sure you were using the torque wrench properly?
Old Oct 26, 2004 | 04:52 PM
HotXB's Avatar
N.G.S.O.
59lbs is way to much for such small nuts.
Old Oct 26, 2004 | 06:21 PM
crawfordna's Avatar
I checked the calibration on my torque wrench just to make sure, it appears to be dead on. The other bolt that isn't used in the mounting of the strut brace checked out right at 38ft-lbs from the factory, so I know it's correct.
Paul at McGeorge parts is taking care of me and will send a replacement as soon as they're available, they're on backorder right now.
--Nick
AxRxP
Jan 25, 2015 08:40 PM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
hampton1100
Jan 2, 2015 08:13 PM
scioninla
14
Oct 18, 2003 03:46 AM
