View Poll Results: What headlamps should i use..?
05-07 Headlamps with shroud method
41.67%
2008 Headlamps and look stock?
58.33%
Voters: 12. You may not vote on this poll
*HID retro dilemma..?*
Old Nov 3, 2007 | 05:55 PM
Yanki01's Avatar
Default *HID retro dilemma..?*
Ok, im currently have all my parts for a new HID retro. Ive purchased a new set of 08 headlamps that come stock with halogen projectors already. My last retro was using the 05-07 headlamps and the shroud method. I liked it because it was more unique and custom looking. I picked the 2008 headlamps because i figured it would be a more easier method since its almost a direct projector swap. On the 2008 headlamps it will probally come accross as another stock looking headlight unless i turn them on then they will see. The 05-07 headlamps with probally be with the BMW e46 bi-xenon shrouds which is what i used last time. I have all my materials needed for the retro at the persons house thats going to do the labor. I told him to hold off for a while untill i make up my mind. I wanted to see what yall thought or would like to see?
Im stealing this pic from Noodle on here.
2005-07 using BMW e46 bi-xenon shrouds...
Originally Posted by Noodle
or the 2008 headlamps, im sure everyone knows what they look like. thanks for the help!
Old Nov 3, 2007 | 06:03 PM
07blackedouttc's Avatar
pesonally ive been looking in to doing this and i think the 05-07 lights look really good with the retro fit
Old Nov 3, 2007 | 06:56 PM
freeflowing's Avatar
I'm in the exact same boat your in except i was planning on doing my own retro fit. the retro fit on the 08 lights are almost a direct swap. so thats where I'm leaning right now. i wonder if anyone tried to pull the projectors out of an 08 camary because they are as twice a good as the ones on the current 08 lights projector lights on the tc.
Old Nov 3, 2007 | 07:26 PM
davedavetC's Avatar
would you be able to do this man? take the 08 projectors and retrofit them wtih HID projectors, BUT use the 05-07 cover? so you get rid of the bubble?
Old Nov 3, 2007 | 08:04 PM
shadow12one's Avatar
I think the 08's look great, use those.
Old Nov 3, 2007 | 09:08 PM
BZinn1's Avatar
do the retro on the 08 projectors but add another set to the highbeams......using the shrouds.....now that would be the best......may cost a little more to get another for the highs but the look would be nice.
Old Nov 3, 2007 | 09:46 PM
Yanki01's Avatar
too much work and i would have to buy another set of 05-07 headlights for it.
well im using Infiniti FX35 projectors which are bi-xenon (aka hi and low beam). So no point in that and i dont want 4 projectors. Just double the work which i dont want.
Im leaning towards the 08 and get it done....still dont know for sure?
Old Nov 3, 2007 | 10:16 PM
You also generally dont want a separate set of HID projectors for Hi-beam simply because projectors dont just turn on instantly to their full output. They take a few seconds to warm up. You dont usually have the hi beams on for an extended period of time so they end up being rather useless
Old Nov 3, 2007 | 10:22 PM
striker_1818's Avatar
Get a Quad Setup using the reflective based headlights (pre 0
You can do s2000 and fx35 with an e30 lense swap (TFX isn't great as many on hidplanet think and if you want a sharper cutoff, use the e30)
Anyways, the 08's look like ebay headlights so that's a no-no really. however, on the positive side, swapping projectors on the new ones will be easier if you have the tools.
Old Nov 4, 2007 | 01:11 AM
I dont think he wants to do the work of putting in quad HIDs or swapping out stock 08's.
Old Nov 4, 2007 | 02:20 AM
Noodle's Avatar
If it is up to me, I would either do 05 - 07 with fancy shrouds, Or do a quad for 08. If you're not doing a quad for 08, then at least install halogen projectors to the highbeams so your retro would look distinctive and unique. It would be wasteful to invest money into a project and people cannot distinguish it to appreciate it. Despite your improvement in vision, which is a primary reason for retro, it doesn't look unique.
Old Nov 4, 2007 | 02:26 AM
thats quite easy but the problem is will the newly installed lens effect the output of the hid projector i plan on installing. i really not trying to bake my headlights twice just to find out.
i may do an 04-07 headlight retro fit down the road
Old Nov 4, 2007 | 04:21 AM
why not? fx's are cheap as well as valeos. A cheap quad will give you some pretty good intensity hence it uses 4 projectors. i'd his setup
Old Nov 4, 2007 | 04:38 AM
Its not about the cost, its about the work he would have to do
Old Nov 4, 2007 | 05:12 PM
it'd look sweet regardless though lol
Old Nov 4, 2007 | 11:15 PM
Yanki01's Avatar
im going to go with the 05-07 headlamps. I just purchased a set of e46 bi-xenon shrouds. Now i need a set of 05-07 headlamps.
Old Nov 5, 2007 | 01:33 AM
didnt the 08's win in your poll?
Old Nov 5, 2007 | 01:36 AM
Yanki01's Avatar
yea, i also had another poll on HIDPlanet.com and the 05-07 won 10-7.
Old Nov 5, 2007 | 01:49 AM
all4degame's Avatar
05-07 bro, 08 imo don't look as clean.
Old Nov 5, 2007 | 01:52 AM
Yanki01's Avatar
they look nice on SW imo. Other than that they kinda come off as eBay lights the more i look at them. Glad im going the 05-07 route!
