What size tires should i get?
Old Nov 5, 2007 | 12:27 AM
rolldawg's Avatar
Default What size tires should i get?
I am planning on geting a set of Sportmax 501 in 15x8 soon. I was wondering if anyone can help me on what size tire I should purchase for them? I have been reading that some have been going with 195 50 15 or soomething like 205 50 15. What is the difference between the two tires sizes?
Old Nov 5, 2007 | 01:08 AM
Super-Stormtrooper07's Avatar
a standardized size for 15" is 15X7. Sounds like you want to go wider w/ the 15X8 size. A 195/55/15" would be close to the stock calibrations , or a 205/55/15" is also very close to stock rotational dimentions.
Hope this helps.
Old Nov 5, 2007 | 12:19 PM
TerribleTed's Avatar
the difference between the 2 sizes you list is the width. The 215 is wider. The stock 15 inch tire is a 60 series a 50 series is going to be very short. Speedo will read fast and rpms will be notably higher at all speeds. A 55-60 series in 205-215 is your best bet with the 60 series being closest to stock as far as diameter. With an 8 inch wheel width the offset you choose will be critical to avoid rubbing.
Old Nov 6, 2007 | 02:59 AM
use this calculator.. its your best bet:
http://www.miata.net/garage/tirecalc.html
Given what I mentioned above... those are your two best options for tire sizes.
Old Nov 6, 2007 | 03:15 AM
Is a good calculator i look at it often.
Old Jun 17, 2008 | 04:09 PM
Bsbox's Avatar
So with a 15x8 wheel and 205/55 tires what offset would you need not to rub if you also had a 2" drop?
Old Jun 19, 2008 | 01:15 AM
ChampionJeep's Avatar
I was running the 501 with the stock 185/60/15 tire and had no problems in the rear with rubbing. I'm on df 210's. The front I had some rubbing but it was the rubbing was the small rib on the sidewall where the tread connects to the sidewall. I was also running a Toyota Echo strut fot an extra 1/2" drop.
Old Jun 19, 2008 | 01:32 AM
firesquare's Avatar
now with my 501's i had 2 different tires but same size. the falken ZIEX 512's fit perfectly. the stretch was sexy and they lasted for about a year with my driving. (25K i guestimate) now i got some junkass Federal tires and im rubbing all over the place. but just in the RR..
Sportmax recommends Falken tires. (shameless plug)
rain7905643
Mar 14, 2015 12:48 AM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
mdhyre
Dec 7, 2014 12:52 AM
SkateVandal
Nov 27, 2014 02:34 AM
GreatWhitexA
11
Dec 23, 2003 05:25 AM
