Problems with my Injen CAI
Old Nov 9, 2007 | 06:50 PM
soisauce757's Avatar
Default Problems with my Injen CAI
I had recently purchased an Injen CAI and installed it myself...besides having trouble installing the second pipe(the actual CAI part that drops down into the front bumper) and keeping it as a short ram intake for the time being untill i have more patience, my car now idles very funny and my car vibrates more...the rpm's after starting it will bounce a little up and down and i do not know why this is happening when my friend has the same exact CAI on his tC and his is fine??
Old Nov 9, 2007 | 07:04 PM
XIEmperorIX's Avatar
Did you check to make sure everything is put together nice and tight and in the proper position? Did you disconnect your battery during the install (or reset your ECU)? Did you buy the right intake for your year? If you bought an intake for an 05-06 and you have an 07-08 (or vise versa) you will have problems since the MAF sensors are different.
I don't know how to address your specific problem but these are things to consider at least. Hope that helps a little.
Old Nov 9, 2007 | 07:06 PM
Default how do i reset my ecu??
Old Nov 9, 2007 | 07:10 PM
I believe you just disconnect your negative battery terminal momentarily then reconnect it. Then start the car and let it idle for a few minutes. I don't know how long your supposed to have it disconnected (or if it even matters) cause when I installed mine the first thing I did was disconnect the battery so it was disconnected for a good 30-60 min.
trojan105's Avatar
disconnect the negative for the battery for a few mins. then connect it back it. don't forget to reset the windows and sunroof
Old Nov 9, 2007 | 08:45 PM
how do i reset the windows and sunroof??
Old Nov 9, 2007 | 11:09 PM
hawgs74's Avatar
Read your owners manual
What size is the pipe on the injen? I want to put on an AEM filter but dont know what size to get
Old Nov 10, 2007 | 03:16 AM
Scorpius01's Avatar
ECU reset can be done by pulling the EFI fuse, as the ECM is fed power through the EFI fuse, that way you do not have to go through the hassle of initailizing everything
It is worthy to note Toyota cars do not need to have an ECM reset when a performance mod is added, the car is already learning how to fuel the car within a couple of miles of driving with the mod. Car computers have advanced alot.
Faulty install is the probable cause of why the car runs weird.
Old Nov 17, 2007 | 06:22 PM
goaliesmk's Avatar
i love when people have problems putting in a cai
hampton1100
May 28, 2015 07:32 AM
CrowJenkins
May 4, 2015 04:52 AM
Crhutto
Mar 12, 2015 10:22 PM
sanders_scion
Scion tC 2G Forced Induction
Jan 20, 2015 04:54 PM
Phillip_Injen
39
Nov 4, 2003 10:38 PM
