DIY Project..
Old Nov 10, 2007 | 08:48 PM
TCBUNNY's Avatar
Scionetics
Scion Driven Girls
Default DIY Project..
I am thinking of doing some DYI painting for some interior pieces on the tC:
*gauge cluster frame
*vent covers
*door handles
*center console waterfall thingy
I will be making these white to go with the exterior color. Any ideas on the best way to do this? I've looked at other threads and it seems like everyone has a different method. Any suggestions?
Old Nov 10, 2007 | 09:03 PM
Jiggaman's Avatar
Big Sky Scion
sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand sand
primer
paint
flawless prep work is the key.... :D
Old Nov 10, 2007 | 09:08 PM
Dakine's Avatar
Concept in Motion Crew
buy my gauge bezel!!!
Old Nov 11, 2007 | 07:20 AM
FLEA's Avatar
Remove all pieces that you want to paint.
Scuff the pieces until it's dark....no more silver.
Clean scuffed pieces with rubbing alcohol or a spray solvent.
Wipe dry.
Apply thin coats of paint at least 8 inches away. Multiple coats.
Wetsand painted area only if you get runs or experience roughness (I used 1000 grit).
Apply at least 3-4 coats of paint and 2 coats of clear. Applying clear and wetsanding it is the same as doing the painted parts.
Have patience and allow plenty of time to dry.
Reassemble.
Buff with a rubbing compound (I used Meguiar's Scratch-X and add a layer of wax to give it a nice shine).
Maintain it.
DO NOT RUSH, OR IT WILL LOOK LIKE CRAP!
Pictures of mine, color matched Flint Mica paint:
If anything, I might add a little more clearcoat later.
Will take day pictures tomorrow.
Old Nov 11, 2007 | 09:54 AM
HaYnSktC's Avatar
flea basically covered it =)
i put primer too tho
just dont go too crazy on the paint
Old Nov 11, 2007 | 11:50 PM
Jdub86's Avatar
MN Scions
That looks good with the Carbon Fiber Accents.
Old Nov 12, 2007 | 12:02 AM
TeeCizzle's Avatar
Basically ALL u need is:
Mineral Spirits...Clean off plastic parts...Let dry before painting..
Fusion PLastic Spray Paint...3 coats
Then ClearCoat...2 coats
[b]NO[/] sanding or primer needed
Old Nov 12, 2007 | 01:02 AM
toeveryhour's Avatar
I'm currently in the process of doing this.
it's turning out pretty good.
just a pia, lol
Old Nov 12, 2007 | 07:54 AM
Jdub86's Avatar
MN Scions
You didn't prime or anything? Just cleaned it very well?
Old Nov 12, 2007 | 07:56 AM
HaYnSktC's Avatar
fusion plastic paint is made to stick on plastic without primer =)
Old Nov 12, 2007 | 01:50 PM
Sieruc06TC's Avatar
i woulda aleast thought you def would need to sand..
Old Nov 12, 2007 | 02:07 PM
TeeCizzle's Avatar
YUP!. NO sanding needed..Use MOneral Spirts clean well...Let dry....
Then Spray Paint!.....
Old Nov 12, 2007 | 03:28 PM
GQQSE13's Avatar
too bad you didn't have a NB one or else i would depending on price.
looks good!! definately a helpful thread as i am going to do that once i get my paint in.
Old Nov 12, 2007 | 06:56 PM
HaYnSktC's Avatar
^just buy his get it sent to me and ill paint it for you hah
Old Nov 13, 2007 | 06:53 AM
Resu's Avatar
Wipe dry.
Reassemble.
Maintain it.
That looks great! OEM paint? How do you like the flint against the black of the rest of the car. I love the carbon fiber look, great work.
Old Nov 13, 2007 | 08:04 AM
FLEA's Avatar
I like it A LOT! Get tons of compliments on it and it just seems to go hand in hand with the black dash and everything else. It's a really easy mod to do....but it's also really easy to f**k up too. If you're going to do it, take your time.
My favorite thing about this mod was getting the OEM paint in a rattle can from a local paint store. It took them 10-15 minutes to make it and it only cost me $16. A lot cheaper than paintscratch.com and automotivetouchup.com
Old Nov 13, 2007 | 08:52 AM
icemanscion's Avatar
Im about to paint my interior pieces after paying someone to do them and they turned out with problems. Also i wanted a color change, heres what they look like after being scuffed from blue to under the silver.
and here are the products im using
anyone have any suggestions on where to paint at? i cant paint inside my house and i think its to cold to paint outside i live in chicago. Any other tips?
Old Nov 14, 2007 | 05:41 AM
Resu's Avatar
what store did you go to! I know anyone at Autozone wouldn't even know and or would not have it ..or eff it up.
Old Nov 14, 2007 | 06:52 AM
JoeBozz's Avatar
nice mod
Old Nov 14, 2007 | 08:04 AM
FLEA's Avatar
Try to paint in a garage or a warm covered area. If you paint somewhere cold or where your pieces get condensation on them then you will experience problems with the paint sticking to the plastic and drying.
Resu- Oddly enough the place that I got my rattle cans from is called "The Paint Store". They specialize in all types of paint from around the house to cars, boats, and motorcycles.
