07 to 08 headlights
Old Nov 12, 2007 | 05:51 AM
Jiggaman's Avatar
Big Sky Scion
Default 07 to 08 headlights
Hey guys
I did some searching but i couldnt really find what i was looking for in a straight answer.
I have a 2007 tc, and i would like to get some 08 headlights and custom paint them. Here in lies the problem:
I have HID's from oznium in my headlights, and the bulb size is 9006, and the 2008 headlights are H1 bulbs i believe, correct? I obviously wouldnt be able to use the same HID's, so I would probably just use those ones for my foglights.
are the connections to the 07 oem harnesses the same as the 2008s?
the reason I am asking this is because he has an 08 and wants the 07 headlights, and i have an 07 and want the 08 painted headlights, and we are trying to figure out the bulb situation.
What bulbs are involved in each headlight, would be my question....
thanks!
Old Nov 12, 2007 | 06:06 AM
BlizZard's Avatar
The 08' low beams are h11
Old Nov 12, 2007 | 06:09 AM
andino's Avatar
9006 for the 07 LB and h11 for the 08 LB. if you both get HIDs then just get the kit with a 9006 harness and H11 bulb and vice versa for your buddy
Old Nov 12, 2007 | 07:48 AM
SquallLHeart's Avatar
you're gonna need to get new connections...
i would just cut off each other's plugs, switch, and re-wire them in
Old Nov 12, 2007 | 09:25 AM
Wingman172's Avatar
since you already have an HID kit, all you do is buy the H11 bulbs and swap those w/ the 9006's and your done, if you do this you wont need new connections or to splice anything.
Just install the 08's headlights, swap the 9006 to H11 and put them in the 08 housing and your done.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
atlantaemail
Sep 20, 2015 02:03 AM
