Spacers on a set of 18x7s
Old Nov 12, 2007 | 11:35 PM
ronsweden's Avatar
Default Spacers on a set of 18x7s
Re: Offset and spacer questions.
I am running 18X7 4-100 40HSM , with 225.40x18Yokohama S.Drive wheels. I would really liketo put 25mm spacers on the back wheels. Can I do that without causing rubbing of the sidewalls? I don't lower the car 'cause it's my everday drive, and I can't afford (not do I want) the air system.
Can anybody help? Ron
Old Nov 13, 2007 | 10:52 PM
joshboogie's Avatar
If you don't lower it you should be OK even with a 25mm but a 10mm makes a huge difference.
Old Nov 13, 2007 | 11:59 PM
ronsweden's Avatar
Default 25mm spacers on back wheels of a toaster
Thanks. I am looking at the 25mm 'cause it seems to be the only one that just bolts on to the existing bolts. I'm not into taking anything apart. Am I right on that? Thanks for the help. Ron
[/img]
Old Nov 14, 2007 | 12:12 AM
joshboogie's Avatar
If you are talking about a 25mm wheel spacer them there is no way you're bolting that on with out having longer studs put it and that would be a HUGE pain to do. If you use a 10mm hub spacer on the rear it will be even with the front. Thats what I'm running in mine now. I have the OTG shims but you can get then from keiko (spelling?). The biggest I've seen is a 15mm shim and that would be more than enough.
Old Nov 14, 2007 | 12:31 AM
ronsweden's Avatar
Thanks for clearing that up. Ron
Old Nov 14, 2007 | 12:33 AM
joshboogie's Avatar
No problem.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
stayintrucha
Apr 27, 2015 07:55 PM
Drey
Feb 15, 2015 01:36 AM
CAtC12
Dec 23, 2014 04:44 PM
SkateVandal
Scion xB 2nd-Gen Wheel & Tire
Nov 27, 2014 02:34 AM
