Sieruc06TC
11-13-2007, 01:22 AM
is there any performance with an axle back exhaust...or do i have to change out the s-pipe and mid pipe to get performance..???
View Full Version : axle back exhasut? Sieruc06TC 11-13-2007, 01:22 AM is there any performance with an axle back exhaust...or do i have to change out the s-pipe and mid pipe to get performance..??? whiteshirt 11-13-2007, 01:25 AM Out of an axleback, you should expect maybe 2 or 3 whp, nothing noticeable. And even with an spipe and midpipe, you may gain just a little hp, but you may not get it where you want it, i.e. it shifts the power to one specific part of the power band. Sieruc06TC 11-13-2007, 01:30 AM ahh allrite thanks.... unxpectederror 11-13-2007, 05:07 AM some axle backs will give you upward of 6whp some of the less flowing designs such at the TRD will most likely net you around 3whp though sciontc08 11-13-2007, 11:30 AM im getting a custom cat-back system made...its way cheaper then buying an axle back CuRiOuSfIsH 11-13-2007, 08:40 PM Hmmmmm........ maybe there are gains but butt dyno wont show much. frankie_j_ 11-13-2007, 08:45 PM my advice... by the nts pulley kit, should feel summin there sciontc05123 11-13-2007, 09:48 PM an axel back should give u about the same HP as a neon under your car. I like the pulley kit idea though but it is alot harder to put on if u r planning to do it yourself. You will need an air wrench. If u have a few hundred bucks my advice is an intake and springs!! Mid_Life_tC-risis 11-13-2007, 11:06 PM If you don't take advantage of the SEARCH feature you won't get the full benefits of this site ... A straight-through axleback muffler has been shown to give 5-6whp gains on a manual tC: http://www.scionlife.com/forums/viewtopic.php?t=80070 Replacing the s-pipe & midpipe is a waste of money IMO, unless going turbo (where you will NEED to move up to a 2.5" exhaust.) Putting on a 2.5" s-pipe and midpipe on a naturally-aspirated tC will only serve to kill your low-end torque. |
