PSI on Toyo Proxes 4
Old Nov 15, 2007 | 11:42 PM
ForceNut's Avatar
Default PSI on Toyo Proxes 4
Is the PSI on 17 inch Toyo Proxes 4 tires the same as what is recommended for stock tires?
In other words is 29 PSI in the rear and 32 PSI in the front still appropriate despite the change in tires?
Old Nov 15, 2007 | 11:45 PM
jesterscourt's Avatar
i run 36 and 33. But thats just me. I like better performance and better gas millage.
Old Nov 15, 2007 | 11:46 PM
2_much_tc's Avatar
if you haven't changed the wheel size, keep the same PSI on the tires...
Old Nov 15, 2007 | 11:47 PM
Ace83's Avatar
Ronin Scion
use the recommended psi if its only for daily driving
Old Nov 16, 2007 | 06:12 AM
sciontc_mich's Avatar
Default Re: PSI on Toyo Proxes 4
No need to change the PSI from what the factory tells you. 32 front/29 rear. The proxes4 are good at those PSI levels.
Old Nov 16, 2007 | 07:12 AM
GammaTNT's Avatar
when i got my TP4 they were at 35psi, The ride was bouncy on bumps. so i lower them to 32f and 30r. The ride is better now.
Hydryman
Feb 23, 2016 03:35 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Andreas24
Sep 15, 2015 02:10 PM
