HID's in VRD Fogs ... Lights flicker then turn off... HELP!!
Old Nov 19, 2007 | 10:11 PM
lantagne21's Avatar
Default HID's in VRD Fogs ... Lights flicker then turn off... HELP!!
I ordered a H3 8000k HID kit with relay harness from Pilot HID (already have a 9006 8000k kit from them w/ the relay harness in my headlights). The problem that I'm having is that after I installed the relay harness and the kit, when I turn the fogs on, they turn on for a split second then turn off. If I turn them off, wait a second, then turn them back on, they do the same thing, turn on for a split second, then turn off.
I double checked everything (ground, connections, fuses, etc) and still can't find them problem.
If anyone has any idea as to what the problem could be, please let me know!!!
Old Nov 20, 2007 | 03:46 AM
llblutigerll's Avatar
bad ballast i have hids in my vrd fogs and they r working fine
Old Nov 20, 2007 | 03:56 AM
lantagne21's Avatar
did you use a relay harness?
and I have the fogs wired to come on with the parking lights, I don't know if that would make a difference or not.
Old Nov 20, 2007 | 05:35 AM
aireck's Avatar
switch the connection.... where they connect to the oem harness just flip it....
Old Nov 20, 2007 | 11:50 AM
lantagne21's Avatar
What do you mean by flip it?
Old Nov 22, 2007 | 04:28 PM
lantagne21's Avatar
Never mind, I figured out what the problem was. They were just bad bulbs. I did a group buy with a few of my buddies through PilotHID.com and they just switched the ballast and bulbs that they use and I'm guessing that the first batch is bad because out of 3 kits/6 bulbs, only 1 bulb worked.
O well, thanks anyway for those that attempted to help.
TheTripleC
Jan 4, 2015 06:46 PM
tc_Jake
Dec 31, 2014 01:45 AM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
hatchbox
Oct 3, 2003 03:41 AM
