Mid Pipe
Old Nov 25, 2007 | 05:24 PM
milkman713's Avatar
Default Mid Pipe
What is the best size mid pipe to get on a N/A setup? I have searched all over the forum but nobody gives a clear answer. I curently have Injen CAI, MMW header, TRD Exhaust, and i have no plans for F/I if that is of any benefit.
Old Nov 25, 2007 | 06:45 PM
JPsTc's Avatar
1UP Crew
2.5 in.
Old Nov 25, 2007 | 06:50 PM
jesterscourt's Avatar
2.5 in.
Old Nov 25, 2007 | 06:52 PM
07blackedouttc's Avatar
i have 2.5 from the cat back and its nice
Old Nov 25, 2007 | 10:51 PM
maherdan82's Avatar
2.5 If you plan on ever getting spray or head work done, otherwise 2.25 is the best for NA. I personally put on a 2.5 so it was ready for when i upgrade. I did loose low end torque thoe being NA. Just remember when you are not forcing induction you want some back pressure.
Old Nov 25, 2007 | 11:47 PM
caveman's Avatar
1UP Crew
QFT, and I have the proof....
Old Nov 25, 2007 | 11:56 PM
milkman713's Avatar
So 2.25 is the best across the power band. That means i should just stick with the oem mid pipe since it already is 2.25 right?...
Old Nov 26, 2007 | 01:11 AM
maherdan82's Avatar
Well yes and no.....The size is right but the stock pipe is heavy and incorperates a secondary cat and resonator. Upgrading to a lighter S.S. exhaust with no 2nd cat will improve performance across the power band. Keep the resonator thoe to tone down the rasp from deleting the cats. Best bet is to have a pipe fabbed up at an exhaust shop. Woun't cost much at all just for a mid pipe. If your exhaust sounds good now I would just leave the stock mid-pipe on. I have the MEGAN mid-pipe and its too loud with my current exhaust set-up.
Old Nov 26, 2007 | 01:49 AM
Aroddalobster's Avatar
you have a mmw header/s-pipe right? i think that's a 2.5 inch pipe right there, so you might want to consider getting the 2.5 inch.
Old Nov 26, 2007 | 04:31 AM
RA31925's Avatar
I would agree. im running alpha werks headers, 2.5 S pipe, 2.5 customer exhaust. top end pulls so much harder. I was running stock S pipe for a while and felt that it was choking. once the s pipe was installed, there was a great difference. No numbers as far as dyno slips. but the difference is there. your ___ dyno will tell you Good luck
Old Nov 26, 2007 | 05:53 AM
milkman713's Avatar
Since you say it pulls harder at the top end did you loose low end tourque and HP.
Old Nov 26, 2007 | 06:11 AM
less backpressure usually == less low end torque.
Old Nov 26, 2007 | 06:17 AM
milkman713's Avatar
Good to know. I guess im gonna stick with my OEM and mybe later get a custom 2.25. Cuz my header sort of stripped my tc of its peppy acceleration, and this way i can keep whats still there.
Old Nov 26, 2007 | 01:06 PM
JPsTc's Avatar
1UP Crew
Less backpressure usually = more power in FI engines right?
Im getting ready to install my MMW header and S-pipe and am still kinda worried about loosing that low end torque, even with the s/c.
Old Nov 26, 2007 | 05:42 PM
maherdan82's Avatar
If you are s/c I really wouldn't worry about it. The header and s pipe will greatly benifit you.
Old Nov 26, 2007 | 05:46 PM
maherdan82's Avatar
I'm still N/A at the moment and when I installed my header and exhaust I could notice a change of low end pep. My cars all top end now. Kind of sucks when just crusin in and out of traffic.
Old Nov 26, 2007 | 05:57 PM
JPsTc's Avatar
1UP Crew
Once i get it in, im going to have a mid-pipe done by an exhaust shop (2.5in.) to connnect it to my injen axleback. I'll let you know about the change in low end torque.
Old Nov 26, 2007 | 10:29 PM
maherdan82's Avatar
Just remember to have a resonator or two welded in the mid-pipe. I have one resonator and also have the injen exhaust.......still raspy!!!
Old Nov 26, 2007 | 11:34 PM
JPsTc's Avatar
1UP Crew
^Yea, Im def. gona have a resonator installed
Old Nov 29, 2007 | 12:45 AM
RA31925's Avatar
yes i did unfortunately, but it usually picks up around 4k. off the line i get tire spin depending on how i am launching. second gear again spinning. and this is with the stock tires. but i would neve go back to the stock s pipe. you should definitly add a 2nd resonator if you have headers and no cat. it so raspy it will drive you nuts.
