View Full Version : Non Scion Alarm
Piston
01-04-2004, 09:16 PM
Hey just wondering if anyone has done an aftermarket alarm in the xB yet. I am looking to do a DEI Python 881xp. I just want to know if there are any tips anyone can offer.
I noticed that there isnt any removable underdash like on most car, so I am just wondering if anyone know a few secrets that they care to share before I do my install.
Jason
tintsem
01-05-2004, 12:56 AM
Its a very easy install. This should help
WIRING INFORMATION - SCION / XB / 2004 / Remote Start
12volts white/blue and white/red + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock blue/white - driver kick, 14 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock yellow/black - driver kick, 14 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/orange 5wi driver kick, 9 pin plug
Unlock Motor yellow/green 5wi driver kick, 9 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/white - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link connector, pin 9
Notes: The data link connector is below the fuse box.
Wait to start N/A
Brake Wire green/red + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white/red - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
rolex87
01-05-2004, 01:42 AM
I'm not sure how to install them, but I've got a Viper 790 remote start with all the bells and whistles. It's a nice alarm, and it doesn't go off in the middle of the night like some crap alarms do. The LCD remote is also pretty cool.
Mike R.
tintsem
01-05-2004, 02:35 PM
My shop is a DEI Dealer if you need it installed you can let us know. We will give you a fair price. PM me if your interrested.
2fixA
01-05-2004, 02:54 PM
I got my alarm installed at Best Buy, bought a 2 way pager alarm by Black Widow, which falls under that group of companies with a bunch of different names but made by one manufacturer, I thought it was DEI, but don't quote me on that... Either way I love it, especially with the luck I've had with my cars here in California (5.0 Mustang stolen from in front of my house, then the xA getting hit a week after I bought it) I can't help but be a little paranoid
