pulley question
Old Dec 1, 2007 | 09:09 AM
bsp_in_sc's Avatar
Default pulley question
i been looking for a little while now and i cant find a clear answer.
ok there is 3 pulley right, i know the crank is the main one.
you gain the most hp from that one, or gain same from all 3?
what estimated gains from each? is it really worth getting all pulleys?
Old Dec 1, 2007 | 02:45 PM
hawgs74's Avatar
http://www.nonstoptuning.com/pKitToySciTC.htm
Old Dec 1, 2007 | 04:59 PM
bsp_in_sc's Avatar
but im just saying what should i oreder for the best hp gains, and is it really worth getting all of them? or just the crank (underdrive i believe???) i wanna put all my mods on next weekend so i can feel a good gain
Old Dec 1, 2007 | 05:26 PM
SVicksTC's Avatar
I just have the crank pulley because i know when you start putting the other ones one you loose power to your electronics, A/C etc...
Old Dec 1, 2007 | 05:51 PM
GammaTNT's Avatar
there are 3 types of pulley.
Lite weight, Over drive, and under drive,
If you get the Over drive pulley for the alternator, You will get MORE power for your electronics.
Old Dec 1, 2007 | 07:16 PM
NonStopTuning's Avatar
In a very very small nuttshell...
1. All NST pulleys are roughly 70% lighter than the OEM pulleys they replace. The more NST pulleys you use, the more weight reduction. The more weight reduction, the better the throttle response. Having said this... obviously the crank pulley is the heaviest of all the pulleys and thus, changing to the NST crank pulley will provide the most noticeable gains when compared to the rest of the pulleys.
2. The electrical system runs just as well, or better than stock, when a full (3pc) NST kit is used. NOT slower, NOT weaker, etc. Any arguments other than this are simply not valid. PERIOD.
3. Other accessories work very well when NST pulleys are used. Customers using full NST kits have reported no issues of any kind when using NST pulleys.
Not all pulleys are created equal. Not all pulleys are NST pulleys. Theories, myths, and horror stories associated with cheap, low quality, knock-off pulleys DO NOT apply to NST products. Period!!!
Old Dec 1, 2007 | 07:40 PM
SVicksTC's Avatar
are you inplying the to the over or under driven pulley sytems because if you under drive your cars elecrical system it is going to perform weaker how could it perform better, if you Overdrive it i would believe it would perform better but not underdriven
Old Dec 1, 2007 | 07:42 PM
bsp_in_sc's Avatar
i spoke to someone from nstonaim helped me lots, great help
Old Dec 1, 2007 | 10:46 PM
satyrone's Avatar
im thinkg of running pulleys too but like up abovei dontknow if i should run hem all or just the one,crank pulley since alot of people run those.
Old Dec 2, 2007 | 04:18 AM
mengsta's Avatar
you mightaswell do all 3 while yur at it. Ive heard good things from people with the whole set. I myself have a brothers lightweight pulley. Dint wanna change the Oem size. Still feel a good pull.
Old Dec 2, 2007 | 04:54 AM
bsp_in_sc's Avatar
75% of power gained from all 3 of them is just from the underdrive crank pulley
Old Dec 2, 2007 | 06:03 AM
satyrone's Avatar
yeah i was gonna do all three cuz well hey its not that expensive and ive heard great things about running all three. and im more likey gonna go with NST. ive heard nothing but great things from them!!
Old Dec 3, 2007 | 12:09 AM
mengsta's Avatar
Yeahh thats exactly it. Plus NST has good customer service. I just got a lightweight instead of underdrive because i plan on going S/C.
Old Dec 5, 2007 | 12:43 AM
satyrone's Avatar
nice yeah im more likely gonna run the three cuz im gonna stay N/A i was gonna turbo but decided not too!!
Old Dec 5, 2007 | 03:10 AM
mengsta's Avatar
Cool cool come back and tell us how it is wen u finally install it.
Old Dec 5, 2007 | 04:10 AM
satyrone's Avatar
Word ill do that!!
Old Dec 7, 2007 | 09:11 PM
NightShade's Avatar
when replacing all three pulleys with NSTs, is it true that the belt for the crank have to be replaced with a different size while the alternator,etc uses the OEM belts? Thanks.
Old Dec 7, 2007 | 09:23 PM
hawgs74's Avatar
Not exactly -- U only have to change the belt if u get the smaller crank pulley.
Alt. and water pump dont have their own belts
Old Dec 7, 2007 | 09:28 PM
NightShade's Avatar
thanks i was jsut looking at the NST belt guide page and saw that the crank would require something different. Im looking to get the underdrive pulley, etc, but need to wait till spring and find someone to install them. Thanks.
bsp_in_sc's Avatar
yes, underdrive crank pulley needs a new belt, the other two are the same size, so you can run that stock belts...
now if you get the lightweight pulley you dont need it, just with the underdrive
