Right hand mirror issue
Old Dec 5, 2007 | 09:43 PM
Vang2k's Avatar
Default Right hand mirror issue
Ok. I just broke off my right hand mirror while backing up and hit a trash can. I took off the mirror and found that one of the screws out of the 3 that was holding it broke off. I glued back the plastic things that held the 3 screws back onto the turn signal mirror and plugged it back to the wire. I than screwed 2 of the bolts to the remaining 2 bolts.
After that I tried to use my right turn signal and the right blinker on my mirror doesnt flick anymore like usual..? I can still adjust the mirror but the light on it is not working anymore. Hopefully nothing bad happened to the wires...
anyone have a similar situation? I just placed an ordered for a new right hand turn signal off trdsparks.
Old Dec 6, 2007 | 12:40 PM
BrEaK_AwaY's Avatar
did you shatter the LEDs? were any wires spliced?
Old Dec 6, 2007 | 08:05 PM
Vang2k's Avatar
everything is still good. its just the plastic holding the 3 nuts in, one of them broke off. i dunno why after i took off the mirror and put it back on the led didnt blink no more. is there a way to reset it or something? what if after i get in my new mirror and it doesnt signal no more either?
Old Dec 7, 2007 | 12:18 AM
BrEaK_AwaY's Avatar
i got no idea. the only thing i can think of is a wire spliced, the leds busted, or the wire connecter damaged. and u said none of that is the issue. so im not sure. good luck though
Old Dec 7, 2007 | 12:22 AM
Vang2k's Avatar
im waiting for my replacement from trdsparks which should be mailed out tommorow since they had to reorder...i just ordered these ghetto ebay mirrors just in case i run into another trash can...
Old Dec 7, 2007 | 04:30 AM
SquallLHeart's Avatar
check the wiring inside the mirror itself.
yank the painted cover piece off.. and you should see what you need to.
fur_pig
Mar 20, 2020 04:28 PM
mischadoll
Mar 9, 2015 05:48 AM
terrye
Jan 28, 2015 04:47 AM
