Hotchkis sway set, best settings ?
Old Dec 6, 2007 | 11:10 PM
RusWolf's Avatar
Default Hotchkis sway set, best settings ?
Hey guys how is everyone !
I got my Hotchkis sways in the garage and probably will install them tomorrow, i know that they are adjustable , whats the best settings to have them on front and rear ?
Thanks
Old Dec 7, 2007 | 12:10 AM
DonNguyen's Avatar
for daily driving
soft in the front
medium in the rear
Old Dec 7, 2007 | 12:21 AM
SquallLHeart's Avatar
for more spirited driving, i'd still leave the front the softest, and have the rear on stiffest.
Old Dec 7, 2007 | 12:45 AM
draxcaliber's Avatar
ditto, me and kanundrum run that setting too, and our tc's are daily drivers/autocross superstars.
Old Dec 7, 2007 | 12:47 AM
RusWolf's Avatar
Ok so i just keep front on the softest and rear on the stiffest settings and should be the best combination with TRD lowring springs ?
Old Dec 7, 2007 | 01:00 AM
best combination period, because stock ride height or lowered, n/a, turbo or super charged, this combination is just fine.
now depending on your driving preference you may like another setting better, but i've had this combination since last april and i love it, and i also have trd lowering springs and struts, and replaced my trd rear sway with this set.
Old Dec 7, 2007 | 01:24 AM
Scott8's Avatar
what's the point of having the front on the softest? might as well leave it stock then.
I have mine on the hardest level on both front and back. I tried the med and the lightest, but I like the harder feel from the sways. doesn't wallow at all in the turns.
but it all depends on the feel that you like to have on your own car.
Old Dec 7, 2007 | 01:28 AM
chicotunner07's Avatar
damm.....i want these so bad!!!
even on the softest setting the front sway is still a lot stiffer then the stock sway!!
Old Dec 7, 2007 | 01:30 AM
Scott8's Avatar
the whole point of swapping your front sways is to get rid of the wallowing in turns. why just somewhat fix the wallow. stiffen it up all the way!!!
Old Dec 7, 2007 | 03:20 AM
Da_King_Luis's Avatar
i just got these yesterday.. and the springs!!! let us know how the install goes RUS!!
Old Dec 7, 2007 | 04:30 AM
RusWolf's Avatar
Definetly will, i just hope i'll be able to install them tomorrow .
Old Dec 7, 2007 | 02:27 PM
Scott8's Avatar
the rear is easy, but the front is a biatch!!!
a lift will really help with the front. Jack stands suck to do the front.
let us know how it goes!
Old Dec 7, 2007 | 08:31 PM
Keeshwah's Avatar
because too stiff = understeer.
the front needs to be stiffer than stock w/ the hotchkis rear sway because it's so much stiffer than stock.
Old Dec 7, 2007 | 09:58 PM
Lambi4Life's Avatar
Yup, too stiff Up Front = understeer. I've got Hotchkis F&R Anti-sways and Tein SS-P Coilovers and I still run the Soft setting on the front and the Hardest setting on the Rear. I Auto-X and in hard cornering Too Stiff of a setting up front will cause the Anti-roll bar to try and lift the inside front tire (your loosing "independence" in your independent suspension and the car still experiences weight transfer). Add that together with our car's Open Differental, and try to apply some power, you'll get lots of tire smoke from the inside tire and lots of understeer.
My tC is also Turbocharged and I got so tired of not being able to put down the power in the tight stuff, that I bought an 1987 MR2 (that car can rotate!) So now I have 2 cars with 2 different driving and handling characteristics to fit my mood.
Old Dec 9, 2007 | 01:34 AM
RusWolf's Avatar
Sways are not installed yet, my friend who is a mechanic at my job was tied up all day with that convertable mustang , pretty much didnt have time. Ohh well i might do it tomorrow with some friends at home.
Intake is definetly going in tomorrow as well.
i'll update you guys .
Old Dec 10, 2007 | 09:11 PM
hey! just put the sways in yesterday... the front was definitely a pain... they're not joking when they say you have to have patience to re-align the engine cradle with the bolt holes for the front bar.. it took 7 times as long installing the front than i did the rear!
I'll post some pics once i upload them.. I decided to go with hard setting in the front and medium in the back but i think when i install the springs next weekend I'm going to go ahead and set the rear to hard too...
man, what a difference!
Old Dec 11, 2007 | 01:22 AM
5GeorgiaBoi5's Avatar
Front Softest
Rear Middle Setting
Don't run rear alone you will get bad snap oversteer.. I autox and its bad.
Old Dec 11, 2007 | 11:57 PM
Mr_Meaty's Avatar
I had them both on soft with my TRDs. When i switched to Hotchkis springs, I had to adjust my rear to medium.
Now that I'm boosted, I had ot switch my rear to stiff, but my front is still on soft. LOVE EM!
danielv
Aug 26, 2015 07:14 PM
dinkjs
35
Jan 13, 2004 11:55 PM
rodney_ray
9
Dec 31, 2003 04:40 AM
rodney_ray
Dec 23, 2003 08:41 PM
ONEQWICKSCIONXB
Dec 20, 2003 05:44 PM
