View Full Version : how much for spring install?
GloriousMidget
11-01-2004, 09:21 PM
Well, my Tein springs came in a while ago, and after reading the DIY on the spring install, I've come to the conclusion that I'm a dumbass. So, I'll be a pansey and go to a shop to get 'em installed.
How much is a reasonable amount to charge for "professional" spring installation?
Just wanna be sure I'm not gettin ripped off.
Thanks for any info!
squirrel
11-02-2004, 01:51 AM
Any shop should be able to do it in an hour or less. So if a shop charges $60/hour, it should only be $60. If you live in AZ, Randy (randode) will usually do it for a 12 pack. I believe he holds the record for most spring installs, and most spring installs in a day.
I changed my first set of springs with hand tools in less than an hour.
11-02-2004, 05:09 AM
Any professional shop will probably charge you the hour or a little over. Thats if they never worked on a scion. But if they have worked on a scion the charge shouldn't be more than 45min of work. Hope this helps on qoutes. :D
mikochu
11-02-2004, 05:24 AM
I know a couple of locals that will install springs for 60 bucks... Most shops charge 80-120 bucks for an install... The dealer I called a while back said 200 bucks...and they'd only install the TRD springs. :lol:
