finally got my HOTCHKIS springs and TOKICO HP SHOCKS..but
Old Dec 8, 2007 | 11:02 PM
KamikazeScion's Avatar
Default finally got my HOTCHKIS springs and TOKICO HP SHOCKS..but
I don't think I'm going to put them on until next check. I'm looking forward to buy FRONT n REAR camber kit. I was looking on ebay and came across the SPC FRONT n REAR CAMBER KIT for $185 shipped. Is this a good deal or should I just get a the HOTCHKIS REAR CAMBER KIT only for $217?
Old Dec 9, 2007 | 09:00 AM
robtheqb2003's Avatar
Don't really even know if you really need them. I hotchkis springs with tokicos on the way, but have not really noticed any camber issues after the initial allignment...
Old Dec 9, 2007 | 10:30 PM
Tcguy85's Avatar
there is no need for a camber kit, just get an alignment after a couple weeks.
Old Dec 9, 2007 | 10:39 PM
Aroddalobster's Avatar
ooo i'm thinking of doing the same. i have hotchkis springs but i'm planning to upgrade my shocks to tokicos. how are they? and yea u really don't need any camber kits. i barely even needed an alignment after my new springs, but its always good to get one.
Old Dec 9, 2007 | 11:06 PM
So how often do I get an alignment then? Every once a month?
Old Dec 10, 2007 | 01:53 AM
no way. You only need one every year or two depending on the streets in your area...
Old Dec 10, 2007 | 01:58 AM
yeah im at cerritos so yeah maybe once a year. so I guess no need for the camber kit. I'm just going to buy the front and rear hotchkis sway bar then. hey guy from irvine do you know any shops that does installs fog lights/hid kit?
Old Dec 10, 2007 | 02:00 AM
joshlb07's Avatar
Scion Dynasty
yeah i lowered my tc 2" in front and 1.5" in fear. i didnt need a camber kit just a alignment
Old Dec 10, 2007 | 02:16 AM
t_urbo_C_harged's Avatar
hid's are easy kamikaze, if you take your time I am sure you could do it yourself... get either Mobile HID's kit or Operatics HID kit, both plug and play with harness, fuses, and relay! I have used both and both are good kits... and you really can't mess up hooking it up...
Old Dec 11, 2007 | 02:16 AM
Yanki01's Avatar
Im also on Hotchkis springs i actually thought i didnt need a camber kit either. I figured the shop could do it but said something about the bolt wouldnt budge anymore. I was at a -1.9* in the rear and the mechanic at a local brake shop put it to -1.6-7*. He says i would need a camber kit if i wanted it back to stock? Check out this thread for camber....
https://www.scionlife.com/forums/vie...584&highlight=
Old Dec 11, 2007 | 02:11 PM
davedavetC's Avatar
the stock set up doesnt allow for camber adjustment, if you want truely adjustable camber you need to get a camber kit. other wise with a HOTCHKIS drop you will have a lot of negative camber (i know i had the drop and had crazy camber) and you will chew through tires like crazy and you will have a pull, probably even with an alignment. so i would say yes get the camber kit. i have since gotten the H&R coilovers and braught the car up a bit correcting some of the camber but not enough to make me happy
Old Dec 11, 2007 | 11:39 PM
Tcguy85's Avatar
my camber is well within spec after an alignment. they guys at the shop had no problem with it at all.
Old Dec 11, 2007 | 11:48 PM
Mr_Meaty's Avatar
I have the hotchkis springs and the shop I went to was able dial out the camber with the stock adjustments. i beleibe they are withing .9 or something like that.
Seems to depend on what shop you go to.
Seriously, Yankie, who's a$$ is that in your avatar
Old Dec 12, 2007 | 03:18 AM
Yanki01's Avatar
ill try another shop. Its actually the same chika in the last one. Obviously this one is better :D
Old Dec 13, 2007 | 05:33 PM
CSOCSO's Avatar
hm.. thats interesting because i was at the toyota and they did changed my camber.. so how did they to that? i wanted to buy camberkit and as i heard scions got camber kit and you can set it up but not that much.,... if you have 19 wheels then you have to buy an upgraded camber kit.. which is gonna be the same like the stock camber kit but u are able to set it to higher numbers...
Old Dec 13, 2007 | 05:39 PM
CSOCSO's Avatar
BTW i have hotchkis and tokicos (installed already) and to be honest i didnt feel too much difference in the first time.............
i changed my shocks because i wanted to feel some ride comfort -difference.... well i realized if i want difference i must buy different springs because hotchkis is poop........... one of the worst springs to install and to ride.....
well after a few week testing now i would say i do feel some dfference.. not too ... big but now im happier with this setup than the stock shocks+ hotchkis srings.
my bro want to get a scion 2... i will never let him to buy hotchkis springs... there is so many springs out there... tanabe... progress..etc etc they all have nice drops and better ride comfort...
Old Dec 13, 2007 | 06:49 PM
Mr_Meaty's Avatar
Wow. So which other springs on a tC have you ridden in? I'd like to hear from first hand experience.
I've riden in Eibach Pro kit which fealt gret, but a very minor drop, just like my old TRDs. I also rode on Tien H.Techs which were just as stiff as my Hotchkis but not as low, so not worth it IMO.
Plus, my wife thinks my Hothchkis ride fine, so that's good enough for me.
Old Dec 13, 2007 | 07:06 PM
Yanki01's Avatar
yea, the gf thinks the ride could be a bit more comfy ane hopefully koni yellows will do that? she says the drop looks good and i have yet to see a nicer drop than hotchkis.
Old Dec 13, 2007 | 07:21 PM
x2! its just right for me.
Old Dec 13, 2007 | 07:25 PM
CSOCSO's Avatar
shocks wont make too much difference.............. the key is the springs!!!
konis??? did you know you have to modify your front shocks to install konis????? i wouldnt buy konis.......... if u need damper adjustment go with coilovers... if you really NEEED new shocks go with tokicos.. they are CHEAP!! only $400 .. this is cheaper than trd shocks...
