Echo Struts
Old Dec 9, 2007 | 09:32 PM
OC_ScionBox's Avatar
Default Echo Struts
is it true that if i get echo shocks/struts will lower my
xb another 1/2 inch??
im currently running Tanabe DF210
on stock shocks
i need to upgrade now
if so what year from the echo will the shocks/struts fit??
and where can i get them??
Old Dec 9, 2007 | 09:58 PM
Tomas's Avatar
Admin Emeritus
Echo front struts lower the front of an xB Classic about half an inch because the spring perch is mounted a half inch further along the strut.
Echo rear shocks will not change the rear ride height.
Tom
Old Dec 10, 2007 | 02:55 AM
Tom
is there a certain model year i order 'em from
or is the suspension design all the same??
Old Dec 10, 2007 | 04:09 AM
Tomas's Avatar
Admin Emeritus
Instead of Echo struts, order Monroe Sensatrac shocks and struts for the 2002 Echo - do a search here on ScionLife for "sensatrac" for all sorts of discussion and part numbers.
Tom
Tom
Old Dec 10, 2007 | 07:06 PM
swartzautoman's Avatar
ive got the monroer sensatrac echo shocks and struts on my box.
its true, just what tom said.
ill post the part #s latter
Old Dec 10, 2007 | 07:08 PM
ih8you's Avatar
I have been reading through the threads regarding the use of the o2 Echo Struts and only see people using them in combination with the tanabe's and the trd's. Is there any reason you would not want to use these with the goldlines? I just ordered my goldlines today and would like to pick up some echo struts on my way home from work!
Old Dec 10, 2007 | 09:49 PM
im on tien s-tech
Old Dec 10, 2007 | 11:34 PM
thanks bro!
i dont want to end up buying the wrong struts or shocks
Old Dec 10, 2007 | 11:37 PM
n2htwlz's Avatar
Scion Apocalypse
I wish that I did these before I installed the TRD's on my xB . I have seen one out here with the KYB Echo struts and the stance is awesome and the front is the perfect height with goldlines.
Old Dec 11, 2007 | 01:06 AM
echo monroe sensatrac part# for strut is 71575 $68 each and shock part# 5870 $26 each.
Old Dec 11, 2007 | 02:23 AM
Tomas's Avatar
Admin Emeritus
Keep in mind that rear shock part number (5870) is for LOWERED vehicles (shorter shock). For stock suspension height the rear Sensatrack is 5987...
Tom
Old Dec 11, 2007 | 02:38 AM
Tom
so i ask for part number 5870 for the rears and
71575 for the front struts??
just want to make sure
Old Dec 11, 2007 | 01:40 PM
yep
Old Dec 12, 2007 | 07:53 AM
moderngti's Avatar
I've run Xb dampers on my Echo... and yours are much stiffer than the Echo dampers.
You will likely feel a softer ride... but the extra weight of the Scion will likely wear out the Echo dampers quicker.
Old Dec 12, 2007 | 08:08 AM
Big_Bird's Avatar
how about handling
ive heard these are very soft and bad for cornering
Old Dec 12, 2007 | 08:25 AM
moderngti's Avatar
Originally Posted by Big_Bird
how about handling
Absolutely.
The Scion dampers are a BIG improvement over the Echo ones on the echo.. I can't imaging going TO the Echo ones... from a Scion Xb.
The heavy scion will crash into the bumpstops harder with Echo dampers...
Also... you will notice the car more affected by wind when it's "under-damped"
Not something I'd do unless the Scion is really too rough / choppy for you and you want to drive a boat that floats down the interstate.
Old Dec 12, 2007 | 05:01 PM
Gothbox's Avatar
Tom
I think what Tomas is saying as I have understood in the past and have on my car the shorter shock(5870) is for people who are on airbags, or with a major drop, the others(5987) is not any shorter then the stock one just a better ride.
Old Dec 12, 2007 | 05:22 PM
Big_Bird's Avatar
how about handling
Absolutely.
thank you very muh for the info. greatly appreciated
Old Dec 13, 2007 | 04:01 AM
hey what about the TRD shocks??
anybody have them
how would those match with the Tanabe DF210's??
Old Dec 24, 2007 | 06:40 PM
bump
