Help finding Gates belt #K060737
Can anyone tell me where i can get this belt. I just installed the nst pulley set yesterday and i purchased the K060747 belt. Unfortunately i have an 07 tc and i didnt realize that i need a different belt until after it was installed and it started squeaking like hell. After some extensive research i realized that i had the wrong belt. I purchased the first belt from autopro by my house and it took then 3hrs to realize what type of belt i was looking for. Now i called them back today to ask for the new belt and apparently they never heard of that part number. Can anyone recommend where i can get K060737 so that i can fix my car and hopefully stop it from squeaking. Thanks
The K060747 was a tough belt for me to find but i discovered that Napa Automotive uses Gates belts.....One of the only auto stores that i know that uses them Napaonline.com
I did a seach for you but i couldnt find NBH060737 seems that one doesnt exist.....i was able to find the NBH060747
You might need to find out what the dimensions are and find something comparable....wish i could help you more but you might just have to contact Gates directly!
Heres the gates website and says K060737 doesnt exist??
http://www.gates.com/part_locator/reverselookup.cfm
Ok so apparently there is no such belt as the k060737. I went to 6 diff auto part stores including pep boy, 2 autozones, and napa and that belt isn't in any of their database. It goes from 735 to 739. So after trying the 735 and it failing due to it being to short I went with the 739 and it went on just fine and my car is running great now with absolutely no squeaking. So for anyone with an 07 sciont tc that plans to install the nst pulley set the right belt size is K060739.
With that out the way. I love the pulleys. Def noticed a big difference in power and throttle response. I also have the speed source mounts install and the combination of both are amazing. Def recommend the pulleys and mounts.
