BPV on an injen intake
Old Dec 11, 2007 | 12:21 PM
JCM900's Avatar
Default BPV on an injen intake
can i put a BPV on an injen intake
Old Dec 11, 2007 | 12:26 PM
nytlemgr's Avatar
Old Dec 11, 2007 | 12:30 PM
JCM900's Avatar
how did you do that.... was it a big project or an add on.
Old Dec 11, 2007 | 12:36 PM
draxcaliber's Avatar
do it. bypass valves are much cheaper than fixing a hydrolocked engine.
Old Dec 11, 2007 | 12:45 PM
JCM900's Avatar
what kind of BPV should i get... is this hard to install
Old Dec 11, 2007 | 01:08 PM
BrEaK_AwaY's Avatar
AEM is the only company that i know of that makes them for intake systems. and no its not hard to install, because the pipes are pre cut. so just put the filter in between the pipes, and ur good to go.
Old Dec 11, 2007 | 06:56 PM
hawgs74's Avatar
I thought these were a waste until I ALMOST hydrolocked my car. $50 is worth it for some added piece of mind.
Old Dec 11, 2007 | 10:49 PM
JCM900's Avatar
yeah im the kind of guy that is always going to worry about, somthin unless its done right...... i think an injen intake with a BPV and a hydro sheild will be good.
Old Dec 12, 2007 | 12:23 AM
Blackmagix's Avatar
Do you guys know what size the BPV has to be for the injen intake?
Old Dec 12, 2007 | 01:48 AM
hawgs74's Avatar
3''
Old Dec 12, 2007 | 02:32 AM
SengTC3's Avatar
Injen makes a (nylon I think?) cone cover that lets in air but repels waters.
At first I read it wrong, I swear I saw BOV and not BPV, so I was like WTFRIDGE?! a blow off valve on an intake, YOU CRASY!
Old Dec 12, 2007 | 02:33 AM
hawgs74's Avatar
Injen doesnt make filters-- they rebadge others
Old Dec 12, 2007 | 04:21 AM
Haro287's Avatar
I read somewhere that there is cutting/fabrication needed to get the AEM BPV to work on the Injen CAI, is this true or can I just get a 3" BPV and put it in place of where the black coupler goes like in the pic posted above?
Old Dec 12, 2007 | 06:17 AM
SengTC3's Avatar
really? I'm not sure about that, I thought it would just go in between some couplers.
Old Dec 12, 2007 | 11:36 AM
JCM900's Avatar
yeah someonewho has done that want to explain how to do it.
Old Dec 12, 2007 | 03:33 PM
Haro287's Avatar
On trdsparks.com they sell the Injen CAI + AEM BPV as a combo and have, "SOME SLIGHT MODIFICATION MAY BE NEEDED." written in the description.
You can buy it here.
Old Dec 13, 2007 | 03:17 AM
nytlemgr's Avatar
I started to get a ton of PMs so I will try to answer the most common ones here...
Q1: Where did you buy our intake in BPV?
I bought my combo from Sparks Toyota: CAI/Short RAM with Bypass Valve Combo-Polished (it is also available in Black)
Q2: Was it easy to install? Did it require "SOME SLIGHT MODIFICATION"?
In my picture I did not modify anything, everything is as you see it when you take it out of the packages. However, this was not an easy task but obviously not impossible, help from a friend is most likely necessary. (My neighbor saw me struggling to get everything lined up and came over to lend a hand.)
To have everything fit/align properly with out a battle you would have to cut/trim the intake. A pattern as to where you cut is provided with the BPV.
Q3: Are those the original clamps that came with the combo?
No, I was checking out my friends newly built Advance Auto and I came across those. I think they were made by APC.
Keep posting the questions and I will do my best to update this if I know the answer. Thanks!!
steeze69
May 24, 2021 02:57 AM
carid
Feb 10, 2019 10:46 PM
Nkelly
Sep 7, 2015 05:06 PM
Chrono
Aug 25, 2015 05:59 PM
