wheres the brain-box for the air pressure sensors
me and a friend swapped wheels and both our air pressure lights are on. the owners man says that if the box can only read sensors coded to that box, so rather then take the tires apart and pull the sensors, i want to change the box, so if anyone could help that would be great.
The tire preasure controller is located behind the right rear seat interior panel. I'd strongly suggest rather than remove the controller, you initialize your tire sensors (not a hugely complex process that is detailed elsewhere on the forum). This of course assumes that you and your buddy both have 2007 tc's or newer. 2006 and before relied on using the ABS system to calcualte tire preasure warnings.
kingofthecrate
Jan 21, 2015 09:28 PM
hotroddelux
Dec 3, 2014 11:33 PM
