AEM F/IC on n/a?
Old Dec 13, 2007 | 12:11 AM
cburglb34's Avatar
Default AEM F/IC on n/a?
will i get any gains?
Old Dec 13, 2007 | 12:39 AM
draxcaliber's Avatar
yes, but not alot, tuning an n/a tc is not the best investment.
best gains would be with intake, header, s-pipe, and exhaust. and even then, it wouldn't make that much more power with a piggyback ecu.
tuning with a piggyback ecu is more for forced induction applications.
Old Dec 13, 2007 | 01:11 AM
cburglb34's Avatar
so how much can i get out of it if i have intake n exhaust no heards
Old Dec 13, 2007 | 01:41 AM
i think at most, you can get 10 whp with the aem f/ic. like i said, tuning really isn't productive on n/a tc's.
Old Dec 13, 2007 | 01:44 AM
let me put it to you this way, your car is already tuned to run making optimal power the way it is already.
so if you tune with an aem f/ic, completely stock, you don't get much results, but you add a cold air intake, header, full exhaust, and you have changed the perameters of the car alittle, so you can optimize how it runs now with these parts, but it really isn't that much of a gain.
Old Dec 13, 2007 | 03:44 PM
chicotunner07's Avatar
how bout a camcon, i heard those do well for I/H/E on tc's and can increase up to 20 HP
any truth to this??
Old Dec 13, 2007 | 04:00 PM
Simplyscion's Avatar
Team No Limitz
aright, how about I give you some good info other than the "it works better for boost, you wont see any gains"
That answer is true for the most part, but the reason why it isnt beneficial for N/A vehicles is due to the fact that the F/IC unit doesnt have the ability to add timing, only retard it. Again, which is good for boosted vehicles where the stock ECU timing is way to advanced to run properly and safely on a mid to high boost pressure system. If you want to extract the most power you can out of your I/H/E combo then you need to go with a piggyback where you are able to add a couple degrees of timing and lean out your A/F ratios safely to maximize your full potential of your bolt on mods. Hope this helps a lil bit as to why this piggyback is more suited for boost applications
Old Dec 13, 2007 | 05:23 PM
paul_dezod's Avatar
Scionetics
KAD
BUT! Unless you are running cams, you will not need much more timing that stock if you run 93 octane at all times. The ECU is pretty good with managing timing on a stock set-up.
Old Dec 13, 2007 | 05:26 PM
Team No Limitz
touche!
Old Dec 13, 2007 | 05:43 PM
paul_dezod's Avatar
Scionetics
KAD
touche!
Gettin ready for the holiday Vito?
Old Dec 13, 2007 | 06:18 PM
Team No Limitz
touche!
yezzir
Hey Im actually meeting up with the kid who goes to school up in Buffalo next week when he comes home for break(possible donor car). Gonna be discussing the EMS with him for the TSX
I will be in touch next week paul
SloTC1
Aug 16, 2018 02:45 PM
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
