rims for an xa, 18s
Old Dec 13, 2007 | 01:09 AM
06xA360's Avatar
Default rims for an xa, 18s
ha all, i just put my xa down 2 in. and im looking to get rims. ive looked at the buyers guide and alot of posts and see alot of info on tc and ab, not so much for xa. i dont know if i just over looked it or sometihng. anyway, id like to put 18s on with a 215 40 18 with a 42mm offset. will this work? if not what would be a good set up? id like to fill the gap as much as i can with out rolling the finders. - ryan
Old Dec 14, 2007 | 12:08 AM
06xA360's Avatar
hmmm, there is no one out there with this set-up or 18s on there xa?
Old Dec 15, 2007 | 07:37 PM
Persocon's Avatar
how wide is the rim? maybe 5 mm spacer for front. It will be fine.
Old Dec 16, 2007 | 01:59 AM
06xA360's Avatar
sorry about that, the set up is 18x7.5 42mm offset w/ 225 40 18. thanks for the help.-ryan
Old Dec 16, 2007 | 07:56 AM
Persocon's Avatar
7.5 is no problem. If you want it to look flush, I would suggest 5mm spacers all the way around, or even 10mm in the rear.
Old Dec 16, 2007 | 04:17 PM
06xA360's Avatar
kool, ill take a look at that. is there any set-up that would look better?-ryan
Old Dec 16, 2007 | 06:09 PM
Persocon's Avatar
what do you mean look better?
Old Dec 16, 2007 | 06:29 PM
06xA360's Avatar
fill the gap any better
Old Dec 16, 2007 | 06:35 PM
Scooter06's Avatar
I have a 18x7.5 with a 42mm offset and a 215/35/18 tire
with the OTG 10mm spacer in the rear. I also have about a 2 inch drop. It doesnt rub in the front at all.It you want it to be more flush with the outside of the body you will need to go with more offset on the rims!
Old Dec 16, 2007 | 08:06 PM
Persocon's Avatar
to fill the gap better, either go lower, or run larger sidewall tires but that will affect your speedometer reading and make the overall height of the car a little higher.
Old Dec 16, 2007 | 11:01 PM
06xA360's Avatar
so, if i didnt wont to use any spacers would i need a 52mm off-set or a 32mm off-set?-ryan
Old Dec 17, 2007 | 05:21 AM
Persocon's Avatar
32 offset. Adding spacers makes your offset on the wheel lower.
Old Dec 17, 2007 | 11:12 AM
06xA360's Avatar
kool, thank you-ryan
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
