MMW Header Install Problems w/ S.C
Old Dec 13, 2007 | 03:16 AM
JPsTc's Avatar
1UP Crew
Default MMW Header Install Problems w/ S.C
So I had a tcpete (great guy by the way) take a look at the MMW Header/S-pipe I have (3rd gen. I think, the header is all one peice) and we ran into some problems.
1)First of all getting the heat shield off of the header, may have to cut it or something.
2)Then actually getting the header in. We already know we have to remove the fan and either take out the radiator or drop it a few inches. We can't put the header in from the bottom because the oil return line is smack dab in the middle and getting it in from the top is gona be a a pain because of the shaft and I really don't want to have to take the shaft apart.
Has anyone installed this header with the s/c already in before? Any help?
Old Dec 13, 2007 | 03:45 AM
draxcaliber's Avatar
really sounds like your going to have to go at it from the oil return line, it would probably be alot easier to do than taking apart the drive shaft.
Old Dec 13, 2007 | 04:12 AM
cee_dub2003's Avatar
From what we have encountered you can install it with everything there. Takes some work but it will go in.
Old Dec 13, 2007 | 04:23 AM
1_kLEan_tC's Avatar
From what I know...you will have to apart the shaft of S/C to get the header in...
Old Dec 14, 2007 | 04:21 AM
Crippie's Avatar
1UP Crew
id probably go with the return line solution... if not, try what Cee Dub mentioned... try to fanagle it in. the biggest problem i think your gonna come across is the heatshield on the stocky. Dremel maybe?! lol
Old Dec 14, 2007 | 11:18 AM
JPsTc's Avatar
1UP Crew
^Yea I spoke to a guy who did it and he said he unbolted the heat shield and cut if off lol. Then he just drained all the oil, unplugged the return line and got it in from below. So thats whats gona end up happening .
Old Dec 14, 2007 | 01:05 PM
m6ar2cel6oTC's Avatar
you gonna use a o2 simulator? and does anyone know where i can get one.. i dont wanna make my own sorry if i am thread jacking! i am getting the same header set up wit my s/c let me know how it goes!!
Old Dec 14, 2007 | 06:39 PM
JPsTc's Avatar
1UP Crew
Yea, im not using the MMW cel elminator though. The one I am I got it off a guy here on Scionlife. Check the sponsord sales section. Im ina rush but if you can't find it ill post up the link.
Old Dec 14, 2007 | 10:17 PM
2_much_tc's Avatar
you should take pictures so that people who might want to put headers after they get the S/C have some knowledge on how to do it. just a thought...
Old Dec 14, 2007 | 10:22 PM
Crippie's Avatar
1UP Crew
DIY write up... sounds like a good idea
Old Dec 15, 2007 | 01:55 AM
JPsTc's Avatar
1UP Crew
^Yea it does, Ill snap some pics whenever we get ready to do it.
Old Dec 15, 2007 | 02:20 AM
i couldnt find it.. when you can send it to me.. thanks! cause i was thinking about getting it from MMW. but if i can get it cheaper somewhere else i will.. thanks
Old Dec 15, 2007 | 03:41 AM
JPsTc's Avatar
1UP Crew
https://www.scionlife.com/forums/vie...cel+eliminator
Or you can use the antifouler trick
bb20inches
Regional - Mid South
Jan 12, 2008 09:38 PM
bb20inches
Regional - Deep South
Apr 25, 2007 05:09 PM
