Guage installs
Old Nov 2, 2004 | 02:51 PM
dgHotLava's Avatar
Default Guage installs
Has anybody added guages to their boxes (i know ppl have).
i am wondering where you tapped into for the signal senders?
oil temp. ???
oil pressure. ???
i have heard of using the greddy oil block adapter for these. are there any other options??
water temp. ???
thanks
Old Nov 2, 2004 | 03:11 PM
Munch's Avatar
I have the oil temp and oil pressure units in my XB. I just used the Greddy oil block adapter for those. As far as the Water temp gauge goes, you can buy and adapter or you can buy the hose that has the bung in it already.
Old Nov 2, 2004 | 03:32 PM
dgHotLava's Avatar
that hose a toyota part??? do you know the part #???
Old Nov 2, 2004 | 03:34 PM
Munch's Avatar
It's not a Toyota part but here is a link:
http://www.optauto.com/index.htm?dep...itemsperpage=9
Old Nov 2, 2004 | 03:36 PM
RPMxB's Avatar
Default Re: Guage installs
... water temp. ??? ...
Here's a pic of my water temp setup:
AC AutoTechnic S7 Water Temperature Gauge & Adapter mounted on top left dash in VDO black cup.
RPM
Old Nov 2, 2004 | 03:40 PM
Munch's Avatar
Yeah I was thinking about that piece also. It's $19.99 + shipping but you have to cut your factory hose in half to use it.
Old Nov 2, 2004 | 03:46 PM
dgHotLava's Avatar
Click the link below for a larger, more detailed view of the above image:
https://www.scionlife.com/gallery/da...8RPMxBNM04.jpg
RPM
whats with the 10 ga. wire??
do you need to ground it? or is that your signal wire?
Old Nov 2, 2004 | 03:48 PM
squirrel's Avatar
Wow, those are really nice, and alot cheaper than the HKS one I have in my Matrix.
Old Nov 2, 2004 | 03:49 PM
Munch's Avatar
You didn't know about that unit squirrel :?:
Old Nov 2, 2004 | 04:06 PM
RPMxB's Avatar
The 10 gauge wire is overkill; it fits in the large lug best. I doubled it over, crimped it, then soldered it.
Yes, you need to ground it with the black wire. The adapter has a grounding nut; but I judged it too weak in design and did not use it.
The positive wire attaches to the top nut of the sender unit. :D RPM
helloninja
Mar 19, 2018 04:50 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
abbfanuc
Jul 19, 2007 12:16 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
