"clunky" manual shifting feel is normal?
Old Nov 2, 2004 | 08:20 PM
lucas9000's Avatar
Default "clunky" manual shifting feel is normal?
ever since i got my tc, the shifting (i have 5 speed) has felt "clunky" or something when shifting from one gear to the next. basically as you're shifting into a gear it feels like it clicks or gets stuck a little before completing the shift. anyway, it's only gotten worse, so i took it into the dealer today.
i just got a call back that they checked the synchro and everything, and even took out a new 5 speed tc that was on the lot and it felt the same. they said the transmission was fine in mine (sychro, etc.). so basically they're telling me that it's normal or how it was intended to be.
i know other people have had this issue (yes i've done a search, but i didn't find anyone who said their dealer said it was ok). what is the deal? i really don't like the way it feels. would getting the twm shifter change the feel (i want to get it eventually anyway)? will getting the twm void my warranty?
thanks for reading all that.
Old Nov 2, 2004 | 08:22 PM
SSMtC05's Avatar
Mine did too till I learned how to shift properly.....just a suggestion
Jay
Old Nov 2, 2004 | 08:26 PM
lucas9000's Avatar
well if shifting while depressing the clutch is improper, i guess you'd better enlighten me on the proper way to shift.
Old Nov 2, 2004 | 08:31 PM
BSP_5c10n's Avatar
Upgrade your clutch... what can I say, stock clutches suck.
Old Nov 2, 2004 | 08:52 PM
blackpearlTC's Avatar
there's nothing wrong with your car. mine feels the same way. the TC shifts a lot better than my 2000 camaro.
Old Nov 2, 2004 | 08:54 PM
iowagary's Avatar
I had a 98 Integra before the tC and the clutch definitely felt different. It felt like the movement between the gears was MUCH easier and there was a lot less resistance. For example, with the clutch in and the car in neutral, I could wiggle the shifter left and right in the middle very quickly with little resistance. I can't do that with the tC. Engagement of the gears, however, feels very positive and solid. I think it's just a different car and hopefully that's all you're running into.
Old Nov 2, 2004 | 11:13 PM
ScummyMcOwnage's Avatar
The shifter is fine. Rock solid in fact. If you still want something smoother get a short throw shifter.
Old Nov 2, 2004 | 11:59 PM
jktscion's Avatar
Shifting smoothly and properly is a bit more than "shifting while depressing the clutch".
Old Nov 3, 2004 | 01:07 AM
SSMtC05's Avatar
Thank You jktscion thats what I was trying to say but I wasnt going to argue with lucas about his shifting since all it is, is depressing the clutch
Old Nov 3, 2004 | 01:09 AM
Harman's Avatar
Well, if your tranny does not make weird when shifting, then you may be just fine.
Old Nov 3, 2004 | 02:27 AM
BSP_5c10n's Avatar
When I shift all I hear is "click-click" kind of like a gun being cocked... it sounds neat.
Old Nov 3, 2004 | 03:28 AM
DelayedTurbo's Avatar
I just make sure the car goes forward and doesn't stall
Old Nov 3, 2004 | 03:46 AM
therotman's Avatar
The feeling is normal
A new short shifter would help
A new clutch would not change the feeling of shifting, only that of the clutch engagement
Old Nov 3, 2004 | 02:32 PM
ScionTCTrav's Avatar
May I recommend.. the TWM Short Throw Shifter??
Old Nov 3, 2004 | 02:40 PM
brian's Avatar
Way too much complaining on this board.
Old Nov 3, 2004 | 02:51 PM
lucas9000's Avatar
as i said in my initial post, the twm is already on my list of mods i want to do. i'm just concerned about possible warranty issues. anyone?
Old Nov 3, 2004 | 04:56 PM
2eZee's Avatar
Default SUGGESTION if you cant make that call for sure
find a friend that knows stick shifters and have him tell you if its f'd.
THe way the shifter Snicks into slots is dead on correct .
Sometimes my shifts arent great cause im going pokey in it,.
so every once in awhile I shift high ( not HIGH as pot ) like at 4,000 rpm and row through all the gears sports style as it was intended for,
MAGIC people,,,,, pure MAGIC, except its not a 4 liter engine but what are u gonna do lol
Old Nov 6, 2004 | 04:33 AM
daggerSLADE's Avatar
the wierd shifting may also have to do with the fact that the car has an electronic throttle .. so that makes shifting feel weird because the revs go up after you let off the gas .. it takes some getting used to .. i wanna get a short shifter
Old Nov 6, 2004 | 05:33 AM
eeyoredragon's Avatar
Your linkage may be dry.
As to the revs going up after you stab in the clutch [dagger], perhaps that has to do with the speed you disengage the clutch? It would seem to me that the momentum of the engine would carry itself a bit faster because all of a sudden it's not pushing against the wheels anymore. Speeds up slightly, levels out, then slows down. Whereas, if you slowly disengage the clutch, the friction keeps that from happening (and eats at the clutch). Anyway, seems like that's how it'd work to me at least.
Old Nov 7, 2004 | 08:13 AM
silverxb's Avatar
i bet you that the shifiting isn't as clunky as a lancer.
