View Full Version : best springs and sway bars on the market.. ....
fusionscion
11-02-2004, 11:21 PM
hey i want to drop my lava box, and stiffen everything up, so what should i do..... i def want to go with a progress rear sway bar but do not know where i can get this part! also what springs are the best for the buck.... i wanted to get the tanabe df210's, i heard nothing but good things about these springs..... so please help out, where should i buy the springs and sway bars, and how much, and what is the best buy.... if there are any other springs out there please let me know.......i did a search also and came up with nothing i was looking for.......please help i want to order be4 da winter..............p
NERD_BOX
11-02-2004, 11:34 PM
hey, i just bought the Goldline Springs pretty cheap from XBBOY and scioninla! They have the hookup! I havent put them on cause of time and stuff! But i have driven another xb with the springs before i bought them and they feel great and look beautiful from outside view! 2" inch drop front and back plus a " no sag " Warranty! Best stance ive seen!
fusionscion
11-02-2004, 11:40 PM
hey i might go with them,,, sorry if i seem gulible right now but i wanna get springs but am totally torn... any body herd of the progress sway bars ,and where to get um..... any other springs that are good??? any pix would be awsome too if possible....thanks again..........p
squirrel
11-02-2004, 11:48 PM
Yup, I recommend Goldline springs also, unless you're getting coilovers. If you're going to get sway bars, there is the Hotchkis set that ioncludes both front and rear, and there is also the Progress rear bar, for more aggressive driving. Most go with the Hotchkis set-up, and will add the Progress bar at a later time.
fusionscion
11-03-2004, 12:03 AM
so goldline is the best hands down im assuming..... so does anybody know where ican get a set for cheap?
also anybody know bout the progressive rear sway, i think ill add the hotckis later, maybe jsut cuz im backwards.....p
thanks for all your help i appreciate it.... also to squirrel, love dat setup wit da rear center exit exhaust, beary nice
squirrel
11-03-2004, 01:10 AM
The Hotchkis bars will bring it up to par and keep it pretty neutral, eliminating most of the handling problems. If you want to get aggressive and start doing some autocrossing, then add the Progress rear bar later.
I'm on TEIN coilovers and Hotchkis sway bars. I also have the TRD strut tower brace. I originally had Spy springs, but if Goldlines were available over a year ago, I would have gotten those.
PM Alex (Bluebox) and see if he knows the best place to get Goldlines. Tell him squirrel sent you.
Thanks for the props.
RogerTTR
11-03-2004, 12:33 PM
FYI, some other options are:
Eibach Prokit, Average lowering 1.6" Front / 2.0" Rear at $223.00 *
H & R, Sport Spring, Average lowering 1.5" Front / 1.4" Rear at $179.00 *
Hotchkis, Sport Spring, Average lowering, 1.4" Front / 1.6" Rear $158.00 *
* = Plus shipping.
Click on the following link for more details:
http://www.tirerack.com/a.jsp?a=DJ1&url=/suspension/index.jsp
Lip
11-03-2004, 03:21 PM
http://www.scionlife.com/forums/viewtopic.php?t=31834&highlight=
i'm running the progressive bar with the goldlines. Highly recommended
http://img46.exs.cx/img46/1240/scionprogressivebar.jpg
squirrel
11-03-2004, 04:27 PM
This would be the set-up I would run if I didn't have the cash for TEIN coilovers and Hotchkis bars. Simple, yet very effective. Most front wheel drive cars usually only need an add-on rear sway bar. If the Goldlines were out at the time I bought my Spys, I would have gotten the Goldlines.
Lip
11-03-2004, 05:14 PM
if that rear bar were any larger...a larger front swaybar would absolutely be needed. Also if the front sway were substantially bigger then the stock front...the rear bar would have to be even larger as well. this setup is pretty neutral
11-03-2004, 09:23 PM
To really help with stiffening up the body roll and have a comfortable ride, I would highly recomend the RS*R springs. Great ride , very low body roll and still put you at a 2in drop stance. :D
available at www.precisionmuffler.com :D
Lip
11-04-2004, 10:15 PM
just added this a few minutes ago. i'll drive the car around after the rain stops
http://img119.exs.cx/img119/7619/dcbar1a.jpg
Munch
11-04-2004, 10:54 PM
That dosen't do anything. I have the same brace on my XB. It's more for looks than and not performance :( You're not going to feel any difference in handling.
squirrel
11-04-2004, 11:58 PM
[quote="Lip"]just added this a few minutes ago. i'll drive the car around after the rain stops [quote]
Yup, strut tower braces on the xB is more for looks. Look how close the strut towers are to the firewall, practically welded to it. There isn't going to be hardly any flex there. At least not enuff to be noticable the way we drive it.
Lip
11-05-2004, 03:49 AM
now who said i was going to keep it this way? i'm welding bars from that DC to the front corners or maybe a little lower. I'm using it to tie it all together. the little 10mm bolts they use to attach the upper radiator support is a joke. for 90bucks its strong and did alot of work for me
think of something like this...sorta
http://www.cpracing.ca/productimages/rx8tri.jpg
btw...has anyone made a masterbrake cylinder bracing bracket yet?
something like this
http://www.evasivemotorsports.com/specials/htdrive.jpg
vid of how a master cylinder flexes. some like this mod...some don't. pedal becomes stiffer like using metal braided brake lines
http://www.driverr.com/DriveRR/Movies/MOV00076.MPG
Epitrochoid
11-09-2004, 05:33 PM
Did you change the shocks too? I'd like to do just springs as long as the ride doesn't suffer.
11-10-2004, 02:34 AM
with the RS*Rs you don't have to worry about the struts messing up. They will wear as normally with the stock springs. :) RS*R is the way to go, especially with a tC sway bar!!:twisted:
http://www.precisionmuffler.com/32cd15d0.jpg
hotbox05
11-10-2004, 02:48 AM
hey gabe you interested in sellin that setup ya got? i like that tc bar
fusionscion
11-12-2004, 02:22 PM
hey i want to oder some goldines today, but have no where to buy um from anybody know wherei can get some from??? ive seen um on hopupracing for 179 shipped........let me know wanna order today
squirrel
11-12-2004, 03:27 PM
PM Alex (Bluebox), he may be able to lead you to some peeps.
squirrel
11-12-2004, 04:22 PM
here ya go:
http://www.scionlife.com/forums/viewtopic.php?t=27509
Looks like I just saved you $20.00.
