piston ques...
Old Dec 18, 2007 | 02:51 AM
es_05's Avatar
Default piston ques...
does anyone no if the je pisons will work with the stock rods? thanks in advance for ur time and attention...
Old Dec 18, 2007 | 02:59 AM
draxcaliber's Avatar
the question i have is why would you use stock rods if you are replacing the pistons anyway? i mean, your already right there to replace with some nice forged ones to take the punishment. why not take advantage of it?
Old Dec 18, 2007 | 03:06 AM
es_05's Avatar
well do you no who sells rods besides dezod?
Old Dec 18, 2007 | 03:10 AM
Soulquarian's Avatar
Another question, are pistons and rods all you need to run higher boost safely?
http://www.turbokits.com/tC_turbo_kits.html
Old Dec 18, 2007 | 03:12 AM
es_05's Avatar
thanks any other places?
Old Dec 18, 2007 | 05:08 AM
etsnet's Avatar
Dezod
Ptuning
Jotechracing
Race Engineering
Just to name a few. I'm sure Todd from TurboToyotas does also.
Way not Dezod?
Please whatever you do don't change the pistons without changing the rods. It will give you nothing but a false sense of security.
Old Dec 18, 2007 | 06:52 PM
So pistons and rods are all that's needed to run higher boost safely?
Old Dec 18, 2007 | 06:56 PM
boostedbox06's Avatar
they are low compression right? Be sure of that of your gonna boost high amounts.
Old Dec 18, 2007 | 07:01 PM
Yeah
Old Dec 18, 2007 | 07:07 PM
satoman44's Avatar
don't forget the bearings right?
Old Dec 18, 2007 | 07:09 PM
Ok, I want to build the motor to boost more.
What are all the things I should get?
Pistons
Rods
Old Dec 18, 2007 | 10:01 PM
etsnet's Avatar
Piston, rods, and bearing are good to build the short block and that should take you to 400hp with no problems. If you wanna be safer or go more power then sleeve the motor. If you want to get crazy then do all of the above and build the head too so you can rise the rev limiter.
Old Dec 18, 2007 | 10:07 PM
Sweet. I'll probably be fine with 400hp :p
Old Dec 18, 2007 | 11:24 PM
RSracer's Avatar
KILLERTC.COM has the best prices I've seen for rods & pistons other than on ebay.
Old Dec 18, 2007 | 11:52 PM
rodlandscion's Avatar
I would go with headstuds too since you're going to have to replace them anyway (stock aren't reusable). And Carillo makes the rods I have.
Old Dec 19, 2007 | 12:25 AM
Mightygnu's Avatar
Easy way, just talk to Paul over @ Dezod. He will be able to set you up with everything!
Old Dec 19, 2007 | 03:06 AM
redrumtc's Avatar
Strictly Scionized
killer tc has the internal on a sale and there dirt cheap
Old Dec 19, 2007 | 05:24 AM
etsnet's Avatar
I didn't think their prices were that cheap.
Old Dec 19, 2007 | 05:26 AM
etsnet's Avatar
Stock studs aren't reusable? What makes you say that or why aren't they reusable? I'm not reusing mine but I don't see why they wouldn't be reusable unless I'm looking at the wrong studs.
