Satellite radio question
Here's a question for any who have satellite radio installed:
Does the satellite radio antenna effectively 'replace' your standard mast antenna or does your car have both?
And if it DOES replace the antenna, how is your reception for local radio stations?
speaking of satellite radio... does anyone know if I buy the factory satellite radio module and install kit, if I mounted the antenna in the A-Pillar trim would the signal still go through? Kinda like the navigation antennas hidden there, I just know it's two different things.
Antennas for satellite radios need to have an unobstructed view of the sky as previously stated. It's not like AM or FM radio where there is a powerful signal that can penetrate buildings and other objects.
My brother has an xA with the optional Sirius radio. His antenna mounts (out of view from peering eyes) directly behind the rear view mirror. I like the concept, but his antenna is more susceptible to dropping out from going under bridges/overpasses and tree-lined roads.
I have an aftermarket Sirius radio and have the antenna mounted on the rear sunroof. I have no problems unless I'm under a bridge/overpass for more than 5 seconds or in an extremely wooded area.
TeeCizzle, might want to educate yourself before speaking. Take a look at page 21.
http://www.directeddealers.com/manua...de-091806a.pdf
It's an external antenna, designed to go on the exterior of the car, where reception of satellite signals are ideal.
The antenna that came with the car kit is magnetic and is meant to be mounted on the (metal) roof of a car or the trunk area. Supposedly it gets better reception when mounted directly to a metal surface, but I haven't had any problems.
ExpresScion, I did have to use double sided tape to get it to stick. I like the location it's mounted since it's not overly obvious as most people don't notice it right away.
Installing the Antenna
The optimum mounting location for the magnetic antenna is on the roof of the vehicle, with a
minimum unobstructed area of 12 inches by 12 inches, and exactly 6½ inches from the rear
roof edge of the vehicle (the length of the rubber antenna cable cover/tail). It is important to
avoid any obstructions that will block the SIRIUS signal, obstructions such as a roof rack,
a sunroof, roof mounted cargo containers, or other antennas. For convertible vehicles, the
antenna should be installed on the trunk lid.
For best performance, it is recommended that the antenna be installed with the rubber
antenna cable cover/tail. This rubber antenna cable cover/tail provides two benefits: first, it
positions the antenna the recommended distance from the rear window, rear door/hatch, or
trunk edge to give the antenna the best view of the sky. Secondly, it conceals and protects
the exposed antenna cable. The rubber antenna cable cover/tail has adhesive strips that hold
it securely in place.
Sedan/Coupe. Mount the antenna along the rear center-line of the vehicle roof, located at the
rear of the roof near the rear window.
Thats a dumb-design that Sirus did...Mine is mounted inside of the windshield...
I just saw these things at ciruit city the other day where the satellite antenna line actually runs into the cars antenna wire with this kit so you get no-interference main lining from your satelite reciever into your cars stereo.
It was like $35-I know they have it for sirius (?XM)
I have XM so here are the things you need to know. First, there are two antennas, one for the terrestrial radio (AM/FM), one for satellite radio. Second, there are various ways to mount the antenna. Mine is on the fender directly behind the AM/FM antenna. Third, the way the cable is run makes little difference, so long as it isn't damaged. Finally, the device described from Circuit City is meant for devices with an FM modulator. In other words, If you have an MP3 player or sat-radio and no AUX jack to plug it in, you could play it through the FM radio. Hope this helps.
crocker
Dec 2, 2014 03:44 AM
