new horn
new horn
i am looking at getting a truck type horn and was wondering if 16 amps is too much draw?
i figured if i had engine running when using it, there should be no problem...
You will need to use a relay off of your factory horn wire to pull power from the battery (the 12 volt wire under the dash is only rated at 30 amps and it needs alot of that while the car is running). You will also need heavy gauge wire running to the battery, probably 12ga or larger. I don't know what the amperage rating is on the factory alternator but I assume it isn't much. This may cause your lights to dim when you activate your horn if it is really pulling that many amps.
Nooooooo the alternator is 90 amps the horn is powered through a relay directly from the battery with a separate inline fuse and there should be no problem. I plan on adding my air horns over the next few weeks myself FINALLY! I bought them for my first car back in the early 70's.
Re: new horn
Re: new horn
found here:
http://www.airhorns.co.uk/product.as...234&deptid=121
THats Not a Horn... THIS is a horn
http://www.hornblasters.com/installs...eets-marauder/
Probably drain the battery every time you use it though!!!!
Good Luck though seriously
Originally Posted by Djbombsquad
http://www.suicidedoors.com/showfullimage.php?type=products&image=4-PCTrainHornCompleteKit.jpg&title=4-PC%20Train%20Horn%20Complete%20Kit how many db's does it produce.
BlingSlade
09-05-2015 08:52 AM
