View Full Version : HoW MuCh NOS???
pechuga
11-03-2004, 11:51 PM
I threw a NX wet kit in my XB! How much NOS can she take?? Right now I have a 35 shot in it, but I NEED MORE!!!! Check out my car:
http://www.01designsystem.com/
so far with the 35 shot the car picks up pretty good, and it'll even do a mini burn out when you spray out of the hole! FUN!!!
BoomBox757
11-04-2004, 02:01 AM
umm I would say that the xB wouldn't even be able to handle a 35 shot very long if your just going to be shooting it for fun
pechuga
11-04-2004, 02:06 AM
really, howcome???
mD5
11-04-2004, 05:14 AM
mine did a 55 daily.
comeon will give the xB a little more credit. you've seen my box in and out. you know i have nitrous..
squirrel
11-04-2004, 06:05 AM
I love those wheels. I saw a set on an Eclipse and fell in love. Too bad I don't have the $$$ and my xB is a daily driver.
pechuga
11-04-2004, 12:37 PM
Thanks man! I love them too!
the_saint
11-04-2004, 04:23 PM
*DISCLAIMER* I'm no expert. :oops: :lol:
I thought the general rule of thumb for nitrous was no more than 50% of the engine's rated HP. 108/2=54. So a 50 HP system "should" be safe. :?
kshymkiw
11-04-2004, 04:34 PM
the Xb is a 1.5 liter 108 hp engine true, butr you need more info than just that, and i haven't this kind of info published out there. For a stock engine i would say a 55 shot. Get bigger injectors and retard the timing a little and you MIGHT be able to go with a 65-70
Munch
11-04-2004, 04:39 PM
You can do a 35 wet shot with no problem, anything over that I couldn't tell you about 8)
jdaniels
11-04-2004, 04:47 PM
There is no such thing as a gas called NOS. It's nitrous, or n2o - NOS is a company, Nitrous Oxide Systems.
So, in closing nitrous and n2o are acceptable terms... this isn't F&F here, we aren't in fantasy land.
the_saint
11-04-2004, 05:56 PM
Thank GOD there is somebody else out there that thinks like me. I hate that damn word "NOS". It's not even a friggin' word, it's an acronym.
I just got soo tired trying to "educate" F-n-Fers about it. It was a losing battle.http://img.photobucket.com/albums/v297/mlsaint78/SMILEYS/rant2.gif
TheRedBox
11-04-2004, 06:27 PM
UsE aS MuCh NoS As YoU WaNt! JuSt MaKe SuRe yOu DoNt BuSt ThE wEldS oN tHe InTaKe MaNiFoLd.
TyPiNg LiKe ThIs Is cOOl
jdaniels
11-04-2004, 09:57 PM
Better make it 2, because you topped at out at 140 today...
Say goodbye to your aluminum floor pans, when your laptop starts saying WARNING! dont close it!!! The floor will fall out right after that!!!
It's going to take more than that crotch rocket...
OH SH*T NAWZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
**insert dramatic cinematic exaggerated explosion**
You can have any beer you want, as long as its a Corona.
Remember the buster didn't run back to the fort.
pechuga
11-05-2004, 02:58 AM
Hey NOS dudes, I use the word "NOS" because it is a universally understood word for "No2" That way, no one get's confused, and my question can be answered correctly without the off topic questions like "what's No2, etc..."
I know NOS is a company, thank you for the correction.
jdaniels
11-05-2004, 02:23 PM
No, NOS is an acronym for Nitrous Oxide Systems, and also an acronym used for New - Old - Stock when referring to parts.
NOS is not a gas, Nitrous is a gas. (n2o)
Lets put it this way, the people that don't understand n2o or nitrous, but understand NOS aren't the people you want telling you what's safe to spray.
eeyoredragon
11-06-2004, 05:52 AM
Remember the buster didn't run back to the fort.lmao
You know... it's almost like you have that movie memorized... lol
fireballfish
11-07-2004, 02:50 AM
Wow... damn.. I'm not here to flame, so I'll ACTUALLY answer your question. I think that if you're using a wet system (does it use an additional injector near the throttle body? I've yet to see a kit on a xB) that you could probably run a 50 jet relatively safely. we have a knock sensor for retarding, and because you're using a wet system you shouldn't run lean... just make sure not to deviate to far from Stoichiometric.
jdaniels
11-09-2004, 01:52 AM
Flame this.
Anyhow, with a wet kit he shouldn't be able to stray from stoich... it SHOULD add fuel correctly, if it doesn't it might as well be in the trash.
fireballfish
11-10-2004, 03:53 AM
Flame this.
Most N2O kits are universal. and thus would require some tuning. you CAN run too rich as well as too lean with a wet system. if you are using a wet system that is adding very little fuel, and your stock injectors can't keep up with how much NO2 you add, it would create a lean condition. If you were to say add a secondary injector that is either too large, and or has it's duty cycle set too high, you could create a rich situation even though your ECM will try to retard the duty cycle of the stock injectors. It's more likely that you'll run too rich, but either condition is plausible and possible.
eeyoredragon
11-10-2004, 06:47 PM
Flame this.
Most NO2 kits are universal. and thus would require some tuning. you CAN run too rich as well as too lean with a wet system. if you are using a wet system that is adding very little fuel, and your stock injectors can't keep up with how much NO2 you add, it would create a lean condition. If you were to say add a secondary injector that is either too large, and or has it's duty cycle set too high, you could create a rich situation even though your ECM will try to retard the duty cycle of the stock injectors. It's more likely that you'll run too rich, but either condition is plausible and possible.well, wouldn't it make sense to tune everything correctly anyway, as spark retard works against the whole point in putting nitrous in in the first place?
mmoran903
11-10-2004, 06:55 PM
Flame this.
woooo keep quoting!
mmoran903
11-10-2004, 06:56 PM
Flame this.
woooo keep quoting!
WOOO AND AGAIN!!11
the_saint
11-10-2004, 07:14 PM
Flame this.
woooo keep quoting!
WOOO AND AGAIN!!11
LOL
Sublimize23
11-11-2004, 01:56 PM
Best. Post. Ever.
fireballfish
11-11-2004, 08:21 PM
Spark retard would only happen if the knock sensor sensed knock, but there is only so far that the ECU can retard, there are parameters that the ecu cannot exceed. That was my whole point in the first place is to tune it properly... that way your ecu won't work against you when using N2O
unlmtdndeavor
11-14-2004, 11:11 PM
i guess ill be the one to answer his question more directly...i ran the xb with a 75 hp wet shot. it was running fine at the track. but then one day i was squeezing with a few poeple in the car...and when i got to the parking lot...my car was not idling well. i changed my plugs thinking that they may have been burned out. but that is not it. i think there is somethin wrong with the timing. and the car is still sitting at home in the garage while im away in college.
SO...dont run a 75 shot without proper tuning. if you were to do it...get a safc. i forget who wrote it...but he is right...the ecu can only correct what the nitrous is doing so much. so stay with a 50 to be safe.
p.s. if anyone knows whats wrong with my car...let me know
u83rp5ych0
11-15-2004, 01:24 AM
Flame this.
woooo keep quoting!
WOOO AND AGAIN!!11
LOL
i have nothing to say to this post except i wanted to keep the quoting going. Wow, im a loser.
Forward_Motion_Motorsport
11-15-2004, 01:48 AM
Just out of curiocity have you done a compression test yet? or leakdown? and i would hope to god that anyone in their correct mind woul;d order a kit and start off small and work their way up before you went all ___ hat with it. Someone had mentioed the correct "so-called" formula for introducing Nitrous to a vehicle given the rated HP divided by half should be appropriate. this is also given i real world enviroments based upon a new car and perfect condition of the engine. as most of us know its not to unheard for a buddy with 176,000 miles on his 94 Civic to be trying out his 125 shot "NOS KIT". i would rather instill in someones mind to go by not the rated hp. but by actuall wheel hp as a safety net for the begginer especially. if your not sure what your vehicles capable of, you should be either searching for a certified shop or searching for qualified help from the original manufacture of the kit. Typically the Zex kit despite the ugly purple bottle is near goof proof. utilizing it as a dry kit anything under 65-maybe 75 shot can be given dry. more complicated tuning and setups are required for wet systems and hey, unless you plan on building the bottom end in your vehicle soon. you should be forewarned that your car has a limit regardless of your wallet. a 50/55 shot is more than enough for most FF stock cars. with bolt ons especially with Daily Driving reliability factors.
BTW most ECU's will correct for about 10% +/- factory original timing/fuel/air curves. but their are many piggyback computers to help with that...
unlmtdndeavor
11-15-2004, 06:18 AM
No i havent done a compression or leakdown test yet...i will be doing that in 2 weeks when i get home from school. and i did have a kit NOS wet kit and i started off with 50 and moved to 65, 70, then 75.
hotbox05
11-15-2004, 08:26 AM
military uses lots of acronyms so does law enforcement and so does the medical field. there is nothing wrong with someone using acronyms. but people who dont know that nos is a brand or what have u and this taht nos is the real gas is dumb. i dont think there should be any reason to ban usin nos as an acceptable name for nitrous. it is almost synonymous.
the_saint
11-15-2004, 02:56 PM
I understand what you're saying, it's just that for me the word "NOS" is extremely annoying. It's just one of those things...it's a peeve of mine.
KingLou
11-15-2004, 04:24 PM
How many people do you hear talk about "in line skates" as "in line skates"........they all call em Rollerblades. It's a common thing........a brand that popularizes a product often becomes synonymous with the product. So I don't think it's appropriate to flame someone for using the term "nos" to refer to nitrous. I personally don't like the term.....but I won't be on someone's ___ for using it interchangeably with nitrous.
KiL
jdaniels
11-19-2004, 10:16 PM
Please don't ever tell anyone to get an AFC... Please... Might as well go ____ away $300 dollars on a set of ground wires and a fuel line magnet. They do just about as much good, and much less bad. :P
Sarcasm, sorry. AFC's aren't really all that great, they modify what the ECU THINKS is the true MAF signal, by doing this it tricks the ECU into adding more/less fuel. BUT!!! Changing MAF signals can affect timing, negatively!!!
11-19-2004, 11:32 PM
Please don't ever tell anyone to get an AFC... Sarcasm, sorry. AFC's aren't really all that great, they modify what the ECU THINKS is the true MAF signal, by doing this it tricks the ECU into adding more/less fuel. BUT!!! Changing MAF signals can affect timing, negatively!!!
Ideally a piggy back is not the best solution , however, in some instances or for minimal tuning a piggyback, in theis case an AFC s the only solution for tuning. tricking the ECU can be done several ways.... i would prefer someone to use an AFC, then a reostat and makeshift wiring. :shock: anyway you look at it thats tuning. and if your not sure what the equipment fully does or how to set it up, you should be asking for help tuning a vehicle. :)
A full engine management system would in the end be less costly the a few piggybacks. maybe you should look at a Haltech system for your needs. :wink:
Tuning69
11-20-2004, 12:30 AM
Never do more then 50% of the stock engine power with out the engine being built. This means a 35 shot or 50 shot. Put in a throttle switch and O2 Cut off. This way only kicks in when turned on and at full throttle and when the o2 sensors sense that the A/F is more the 14.5 either way (lean or rich) it will shut it off. Keep in mind the xB and xA have returnless fuel lines. This makes it a lil differnt then some other cars. Might also want to ungrade the fuel rail to handle the extra fuel. Wet is the the only way besides a direct port for the scions. A dry kit wouldnt work very effectively.
$.02
firesquare
11-29-2004, 11:09 AM
:lol: :lol: :lol: :lol:
