Black Rear Scion Emblem
Old Dec 25, 2007 | 04:07 AM
simplexb's Avatar
Default Black Rear Scion Emblem
Anyone know how to smoke the rear scion emblem? Anyone got a DIY? I'm too scared to experiment myself
Old Dec 25, 2007 | 06:11 PM
fuqua's Avatar
I am planning on doing the front and the back. I was going to clean it, sand it (500 grit), and then have my friend spray it with a paint gun. Just did my hub caps and they turned out awesome (just for the winter and then spring on go the rims)
Old Dec 27, 2007 | 12:03 AM
flbugboy's Avatar
You can do it with a spray can and it will look great! I have done twenty on all kinds of cars (just remove and sanded)
Old Jan 16, 2008 | 04:15 PM
boooosty's Avatar
1UP Crew
I also did the front
sorry for bad pics
Old Jan 16, 2008 | 05:21 PM
miketf1's Avatar
good pics actually! how did you do the front? does it remove the same way as the rear (floss and goo gone)?
Old Jan 16, 2008 | 11:57 PM
roXor_boXor's Avatar
Be aware there is a little surprise for you on the rear on the '08. There are two holes in the hatch with pins on the emblem.
There are a couple of threads about it around here. Here is one:
https://www.scionlife.com/forums/vie...ghlight=emblem
@ booosty:
I like it. Especially the rear on the SW.
Old Jan 17, 2008 | 04:00 AM
fuqua's Avatar
I like your black front and back emblems. can't wait to this.
Old Jan 31, 2008 | 11:14 PM
Bertoxb2's Avatar
what kind of black did you use? ... and who makes it?... i like the color match on the front!
Old Feb 1, 2008 | 01:49 AM
boooosty's Avatar
1UP Crew
Haha, I didn't even try to color match the front, it just happened to be that way
For the black, I used Krylon Glossy Black Interior-Exterior spray paint
For the clearcoats I used Krylon Crystal Clear - CLear Satin Finish
I am planning to use the same paint/clearcoat to do my headlights next
Old Feb 1, 2008 | 01:53 AM
boooosty's Avatar
1UP Crew
It is exactly like the rear
Old Feb 1, 2008 | 04:07 AM
miketf1's Avatar
great now i removed it but i dont know how to stick it back on... the ____ty double sided tape i have isnt water proof. damn emblem fell right off after i washed the car.
Old Feb 1, 2008 | 11:45 AM
broken_20_2's Avatar
Go out to your local automotive store and pick up some 3M doublesided adhesive tape. It comes in a roll and is a couple mm thick. clean off the back of the emblem and the spot on the car. You'll have to cut the tape to match the shape of the emblem. It's a little bit of work, but I've used it countless times in the past and none of my emblems have ever fallen off. It's basically the same stuff that was on there before, only you have to cut it to the correct shape.
lunchbx05
Dec 29, 2014 07:53 PM
umnitza
Dec 1, 2014 06:26 PM
nacy333
44
Oct 4, 2009 11:18 PM
