General Question: AC and Heater at the same time?
Old Nov 4, 2004 | 08:39 PM
Xonic's Avatar
Default General Question: AC and Heater at the same time?
If the temperature slider is set to red (hot air coming out of the vent), turning AC on doesn't do anything to the air right?
Reason I ask is, many people I talked to believe either using cold air with AC on, or using hot air with AC on is "the" way to defrog the inside of windshield.
I believe using hot air with AC off is the best way. I know as a fact that using cold air with AC on makes frogging worse. Not sure if having AC turned on while using hot air helps any. I thought when the slider is set to hot, whatever cold air being produced doesn't even go into the circulation. Is that correct?
Old Nov 5, 2004 | 02:06 AM
DJ_X_Trodinaire's Avatar
you can have it on warm or hot
the ac helps remove the condensation from the glass
Old Nov 5, 2004 | 02:33 AM
TJandBOXCARWILLIE's Avatar
I have, in the past when I used heat, run my A/C. It's like having a Heat Pump system. And it helps in the long run, so I have been told, with the A/C being run.
Hey, I'm no pro at A/C. Who here is? They should post.
Old Nov 5, 2004 | 10:51 PM
iowagary's Avatar
Adding the A/C dehumidifies the air. It doesn't make it hotter or colder with the heat set all the way up. Running the defogger without A/C may or may not help - it depends how wet the air is. I don't like doing it because it drags down the efficiency of the car somewhat, but my girlfriend does.
Make sure to run outside air most of the time - it will actually keep things less foggy than recirculated air, even when it's raining out.
TotalChaos
13
Feb 4, 2015 10:24 PM
rrtxdrvr
Jan 24, 2015 03:08 AM
ScionLife Editor
Dec 6, 2014 11:58 PM
Scionic
39
Jul 20, 2004 02:46 AM
scionspecialistvegas
Nov 7, 2003 07:53 PM
