do grounding kits work and how do they work would you guys recomend i buy one first for my car ive been thinking about it but i wasnt really sure if it was worth it and if it is do you guys think the ebay ones will work good also i think i saw an hks one....THANKS
01-06-2004, 06:27 PM
grounding kits mostly make the idle better. Not too much of a HP gain but there have been some notices. the buy is up to you.
its_ikon
01-06-2004, 08:03 PM
search for happies on this board and he has an affordable ground wire kit that is worth it.
George
01-06-2004, 10:16 PM
IMO, if grounding kits worked they would be standard equipment.
I've measured the resistance between the points that would be connected by the kit and the resistance was too low to measure with a high quality Fluke ohmmeter. If the resistance is already this low, the grounding kit won't lower it any further.
George
KingLou
01-10-2004, 10:35 AM
From my understanding......grounding kits add no power........but help keep power consistent........by providing more consistant sparks at your plugs and so forth. However......I have a feeling the consistancy of your power will depend more on climactic conditions.......temp, humidity, air density, oxygen concentration, etc. But.....people who have installed grounding kits seem to have good things to say about them. It's not like their a horribly expensive add-on.......so I say......worth giving it a shot I guess.
KiL
DJ_SpaRky
01-10-2004, 11:07 AM
George
Resistances can change, you measured with a 1.5V or 3V signal (look in the manual), most cars are 12V, thus that is not a accurate reading, try measuring the ohms of the OEM wiring vs the "Hyper Ground" kits wiring, I bet you'll see a big difference, also disconnect the wires before testing them.
I'm not flamin you, just adding my info.
I personally think that they are a good Idea, as long as they are of good quality (ie braided solid copper wiring, think sheathing, soldered on connectors), esp. if you have a high output alternator, battery, and/or Stereo System.
Just my .98 > $1.
Dave 8)
UrbanDrum
01-10-2004, 11:15 AM
:?: Is one available for our scions? I've been holding back on installing a bunch of stuff that I have for my box cause I'm afraid the alternator wont hang. Our stock ones are 60W right? :?:
DJ_SpaRky
01-10-2004, 11:25 AM
I dunno, I was speaking in general.
It'd be nice if one was, try Stinger (http://stingerelectronics.com/web/homepage_industrial.asp).
EDIT: here's a better link, Stinger Alternators (http://www.stingerelectronics.com/web/prods/alternators.asp)
SPAWN
01-10-2004, 12:52 PM
is the SEARCH button broken? just want to know because there are 3 other topics on this forum that I just read explaining the same thing that this guy asked. common sense , check the forum before you ask a question. JUST my opinion though i don't run this forum.
happies713
05-20-2004, 07:25 PM
i sell ground wire kits for 30.00 Shipped. =)
pm me for details.
George
05-20-2004, 09:12 PM
George
A bit late with a response, but what the heck...
Resistance isn't dependent upon voltage, period. There are only two things that can affect the resistance of a ground wire:
1. Temperature. The range in the engine compartment might make a 1% difference in the resistance of copper. The wire might get hot due to current, but for it to get hot enough to significantly change its resistance would melt the insulation.
2. Frequency. Since we're talking about DC here, there is no frequency to affect the resistance.
So I stand by my measurements. The resistance between the common "ground points" is already nearly zero. Adding another wire won't change it.
George
dinkjs
05-20-2004, 10:37 PM
Ground kits work in terms of giving you power...... if there done right .......check out Hypergrounds wires....they post power increases...so does import tuner magazine when they do upgrades on cars...also Sport compact did an article on them and dyno tested them on a RX-7 and they gained some serious power from them
DJ_X_Trodinaire
05-21-2004, 03:53 AM
check out www.groundfusion.com
read up on their FAQs
handful of scion owners have bought from him including myself
