my dyno pull
Old Jan 3, 2008 | 03:19 AM
hooperstar's Avatar
Default my dyno pull
here are my mods
1. custom cai
2. mmw headers and s-pipe
3. custom s-pipe 2.5 inch exhaust
4. unorthodox lighted crank pully
5. nst water pump pully and alternator pully
6. lighted flywheel and clutchmasters 6puck
7. nology wires
8. unichip
9. 75 shot
http://www.youtube.com/watch?v=v3t5ms4Zheo
these are my numbers without the unichip and also my bottle pressure was only at around 800 psi. If i was at 950-1000 psi I would have hit 300whp Tell me what u guys think thanks
Old Jan 3, 2008 | 03:23 AM
himynameischris's Avatar
great numbers!!!
draxcaliber's Avatar
you wasted your money on the nology wires, toyota's coil on plug design is apparently the best you can have, so you should put that back to stock unless you just like the way they look for car shows or something.
would be curious to see what you make without the nitrous.
Old Jan 3, 2008 | 03:33 AM
2_much_tc's Avatar
interesting... 289hp and 306tq... very nice #'s
Old Jan 10, 2008 | 12:27 AM
monkeysauce's Avatar
I'm confused. How does a 75 shot pick up 150 whp? Is there a typo somewhere?
Old Jan 10, 2008 | 12:36 AM
olaHalo's Avatar
nitrous + street car = lame
sorry
x2 on the nology wires
Old Jan 10, 2008 | 12:40 AM
java09's Avatar
i feel you on that matt but still impressive numbers!
Old Jan 10, 2008 | 12:41 AM
redrumtc's Avatar
Strictly Scionized
Is it a dry shot or wet? Those #s dont look right I had a 75 shot of zex and all the same stuff amd was at 220whp. U have #s so I must trust it very nice dyno #s man!!
Old Jan 10, 2008 | 12:43 AM
keenoh's Avatar
hmmmmm
Old Jan 10, 2008 | 12:46 AM
olaHalo's Avatar
impressive
most impressive
but you are not a jedi yet
Old Jan 10, 2008 | 12:49 AM
java09's Avatar
matt you are on your way to being as powerfful as phil.. great force i sense in you...
Old Jan 10, 2008 | 01:38 AM
kikcaffine's Avatar
Nitrous is like popping a viagra, the pleasure is there but when it goes away you have to pay to get it back.
Old Jan 10, 2008 | 01:39 AM
java09's Avatar
i like that saying!
Old Jan 10, 2008 | 02:03 AM
hooperstar's Avatar
Default my #s
i made 191 whp on motor. so in all actuatility i made about 100 extra horse with 75 shot. heres a couple things to keep in mind.
1. first of all this was a mustang dyno so its legit.
2. my cold air has no filter and my exaust is just 2.5 straight pipe, no resonator,cat or muffler which works really well with spray.
3. my car is gutted which u have to calculate the weight on the dyno so if my car weighed the full 2905 i probably would have only made about 165 to 170 to the wheels. If u want to c what i did to lighten the car go to the topic "scion tc diet plan" my car weighs in at only a lil over 2500 lbs.
Old Jan 10, 2008 | 02:21 AM
05-RS1's Avatar
nice numbers! pretty high though but nice nonetheless
Old Jan 10, 2008 | 02:24 AM
I was reading some other posts, and it seems like your tires are juuuuuust slightly smaller diameter than stock. Does that impact dyno numbers?
Old Jan 10, 2008 | 02:39 AM
hooperstar's Avatar
Default tire size
i dont think tire size matters the only thing about that was the wheels and tire combo added to the weight reduction.
Old Jan 10, 2008 | 02:42 AM
I guess tire size is roughly the same as final drive ratio
How did weight affect the dyno numbers? If weight is an element to the final readings, can't you enter in whatever weight you want before the run, making up for any weight reduction?
Old Jan 10, 2008 | 02:48 AM
hooperstar's Avatar
Default weight
you are correct u have to enter the correct weight to get and actuate reading so we entered 2700 that was with the person in the car.
Old Jan 10, 2008 | 05:44 AM
etsnet's Avatar
Default Re: weight
The weight effects the WHP? That's the first I've ever heard of that. I've dyno'd my car and been there for other tC and never seen a weight entered to figure out WHP.
Also 190whp with no nitrous! I think they need to fix their dyno cuz it's off. Plus the fact that mustang dyno's read lower compared to others so that means with no nitrous your car is making over 200whp on just those mods. That's hard to believe. I'm not calling you a liar or anything cuz you have video but I think their dyno is messed up.
